G44 wrote:I like that gray that the carpet is. Some sort of “textured” looking gray would look nice in my opinion. Black may get a bit warm in the summer and it will show every scratch and smudge. Just a thought. Super cool project!
asa wrote:mtv wrote:Asa,
I realize you have a lot of work to do, but…..I HIGHLY recommend you essentially double the number of rivets in the top wing skins, or at least ones you can reach. Two friends of mine were killed in an M-7 when the top wing skins departed in flight.
In my opinion, those top skins aren’t stuck good enough.
I will look into that, but unlikely my mechanic would ever sign that off without paperwork.
This got me really curious so I googled it. I assume it’s this one?
https://aviation-safety.net/wikibase/40608
A very sad story, looks like the factors had already piled up against them and the wing skin was the final one. Sort of eerie, that was N5656A, my last M7 was N5656L, also on floats in AK during that time.
Zzz wrote:Asa,
In my Bearhawk, my skylight solution included 2 formers that run longitudinally and provide some structure for deformation and hold-down for the negative pressure. As you know, loss of the skylight in flight is a bad deal. Do you think your perimeter hold-down is gonna be sufficient? Never seen a skylight without some span structure.
Edit: just scrolled back and read that you followed Maule drawings for it. Is it a thicker plexi in use?
asa wrote:Zzz wrote:Asa,
I’ve thought about this a lot. It seems like a massive area that is unsupported compared to almost every other airplane manufacturer with similar size skylights. The skylight is standard 0.118” plexi and is built per the maule drawings. I’m convincing myself that since maule produces so many of them and it hasn’t been an issue… it’s not an issue. But I feel the same way as you.
Seems like it would’ve been easy for them to add vertical supports from the “V” of tubes below the skylight to make two single point supports.
Zzz wrote:
Looking at your pics more, I think the sauce is in the sheer number of fasteners.
asa wrote:Ending the year with electrical success. Called my Dad in to stand menacingly in the corner with a fire extinguisher so I could power the old girl up finally. Added power incrementally as I tested and probed with a multimeter so make sure it was getting distributed correctly. Sure enough, it all worked.
Only hiccup I found was that on all 4 mic jacks I swapped the wires for the PTT and MicLo meaning my intercom did not work at all when I tested with headsets. I looked at the diagram and it made sense - I had been reading the jack diagram backwards in terms of which was ring and which was tip. Found this issue in about 7 minutes, could have been hours. Praise be, moving on.
Time to celebrate New Years, no more airplane work until 2023.
