mtv wrote:I’ve heard “Skywagon experts” …….
One of the most dangerous statements on the interweb…
mtv wrote:Yes, it’s essential to touch down with the 185 pointed the direction it’s moving….ie: Straight. And if it starts to diverge, you must fix it, you cant allow a 185 to get very seriously out of whack on the runway. Things happen really fast if you do.
So, best plan is to start on a more forgiving surface, grass, gravel, etc. build your skill and calibrate your sights there, where a bit of swerve is easy to fix. Then, once you’ve got a pretty good handle on it, then and only then, move to pavement.
And there, you’ll find out fairly quick why you started on a forgiving surface.
You may be the Ace of the base, and none of this applies to you. But most of us mere mortals will do well to start on grass or gravel. The airplane can be a little busy on pavement, so it helps to get used to the plane before you go there.
They are great airplanes, no doubt.
Ross4289 wrote:ington6 wrote:H
I went from thousands of hours in nosewheel planes straight to a 185 with zero tailwheel experience about a year ago.
It was really tough for me. The plane was (and still is) a total beast on tailwheel gear..
. Deer? Landing in the sticks for a living, I can't even begin to guess at the times I've turned the lights on to find deer, javelina, coyotes, and the odd mountain lion, crossing in front of me. I've probably had to go around once or twice in all those events, usually a minor blip of the throttle, a nudge on the stick, we play leap frog, and life goes on... This is in a TW airplane that weighs 5000 lbs, and has a 'few' more ponies than a 18X. I am not Bob Hoover, but it seems to me that giving a P-51 all she has in a go around is just trading one hazard for another. Just make it fly.Users browsing this forum: No registered users and 1 guest
