Yeah, cool video and fun to watch folks yank and bank. But that's what you use to keep from going up that canyon. Once nosed in there without realizing it, and already nose up and climbing for all you're worth... You're gonna be in trouble.
Zzz wrote:exodus wrote:If you let yourself to brain fart and get anywhere near a situation such as , narrow canyon, and for what ever reason Not recognized early that things are looking to go to shit and you let your AIRCRAFT SLOW DOWN NEAR Vs, you have no business being in the mountains in the first place. I bet you that most seasoned bush pilots on this forum, may have only ever got themselves into that predicament once in their early days. It's one situation you will not live long enough to repeat often.
I think everyone here knows that. What is being criticized is the optimism with which maneuvers like this are practiced, the false sense of preparation that may come from doing it in a planned and perfect simulation that can lead to people actually believing that a canyon hammerhead (classic thread) is a practical solution for a scenario that is likely never going to be as ideal as our fantasies.
Blu did a fine example of a minimum radius turn, and it was really fun to watch. Nothing wrong with practicing those, and it's fun to boot. I just don't see it as a practical emergency maneuver.
Not if you want a minimum radius turn. Enough speed, yes; extra speed, no. In a tight situation, it's better to be flying at the speed you already need to make that 180 degree turn, than to have to suddenly slow, overbank, drop full flaps, try to do a hammerhead or a wingover, or any of the other extreme things, etc., in order to extricate oneself from failing to use good judgment in the first place.an extra margin of speed is your friend
exodus wrote:.....If you let yourself to brain fart and get anywhere near a situation such as , narrow canyon, and for what ever reason Not recognized early that things are looking to go to shit and you let your AIRCRAFT SLOW DOWN NEAR Vs, you have no business being in the mountains in the first place.....
hotrod150 wrote:it makes sense to slow down some to give you a little more time to see and react. Plus lower speed = tighter turning radius at the same bank angle. Just don't get behind the power curve. In other words, not true "slow flight" but more like observation or loitering or pattern speed.
lesuther wrote:I used to practice in the w. colo area too...and I never found a huge difference in turn radii between turning at a casual 45 degrees and turning steeper if the maneuver was initiated at something close to a clean Vy (in a 182). The higher speed needed in the sustained steep turn just seemed to mostly cancel out the advantage. The lower bank angle gave a lot of airspeed to burn up to gain altitude with during the initial entry. The higher bank angle gave no extra airspeed to burn up.
I'd enter the maneuver over a landmark, and judge how well I was doing over a different one. It was hard to tell if I was any better off at all using a casual 45 degree bank or a steep turn...the difference was fairly small- perhaps a wingspan or two. This was while having zero altitude loss, with electric flaps, etc.
hotrod150 wrote:exodus wrote:.....If you let yourself to brain fart and get anywhere near a situation such as , narrow canyon, and for what ever reason Not recognized early that things are looking to go to shit and you let your AIRCRAFT SLOW DOWN NEAR Vs, you have no business being in the mountains in the first place.....
I disagree (I think). If you're getting into a tight spot, it makes sense to slow down some to give you a little more time to see and react. Plus lower speed = tighter turning radius at the same bank angle. Just don't get behind the power curve. In other words, not true "slow flight" but more like observation or loitering or pattern speed.
Just like you wouldn't go bombing aong at full speed when you have a mile viz, don't do it into a tight spot where you might have to do some tricky maneuvering.
OregonMaule wrote:IMHO
If you fly for fun like most of us here do, I have a tough time figuring how your going to get in a situation where you need that turn.
When I fly around the Idaho mountains I fly the top half of the canyon as opposed to the bottom half. You then have lots of room to turn around, heck 100 MPH is no problem.
Now if the clouds are on the top of the mountains and I know EXACTLY where I am and have run the canyon before I'll run the canyon on the lower half. If it is to narrow to turn around at 60 MPH I don't FUCKING go there.
You want to fiddle fuck around in areas where you fuck up and have to do a 200' diameter 180* turn you deserve what you get. I know how much room I need to turn my plane around with the current wind. When I don't have the room I don't go there. If the wx is that crappy, hell I don't want to be flying any how. I got a camp fire and whiskey.
Tell me again how important it is to get the pop, diapers, cigarets, and beer to the village people. Tell me again why you risk your life to do this.
I was in the risk my life business. SOP give your life to save a person. To save property take very little risk.
G'Day
G'Day
M6RV6 wrote:OregonMaule wrote:IMHO
G'Day
Some peoples fun are others madness!
Some times I like to fiddle fuck around where you have to make a turn in 200', That's how come I have HP and Flaps!
If you want to work, you fly!
Don't go there if you don't want to!, Don't bitch at me if I do.
I don't bungee jump, ride off cliffs with snow machines, or really like to drive down a 2 lane road at 55 mph, But I will skud run down till I have to land or climb (Love IT)
I'll fly up a canyon, and I'll fly down it. If I know where I'm at and sometimes when I don't.
My shoes, My plane, My choice!
I've been in the village with with a sick kid, man with a leg bone sticking out of the skin, baby turning blue, snow machine ski stuck in a guys gut! What do you do, stay there and do nothing. NOPE!
If you can do it and use it you do!!
Some do Some don't!
Go learn how to do this shit so if you ever have to you, you can! right side up or down, day, night, cold or wet, windy or calm, in the mountains or on the flats, Just fly!
Hell if you don't push the edge of the envelope, you'll never know where it is?
IMHO and $.02 You know how much either is worth!
GT
I gota get outa here soon, I just read this??
