In the meantime here's an add to this thread. The Air Research Flight/Operating Manual Supplement for the C-170 and others:
PDF link
The USA FAA approved version may differ when finalized.
Gary
Mapleflt wrote:The Canadian STC allows for a gross weight of 2400 if equipped with an 0-360 @ 180 hp or greater, Yaaaaaaaaa.
akgreg wrote:2250 is the max take of weight with Wing-X for the 170.
50 lb. increase was all they could do even if you have 180 HP or higher.
Mapleflt wrote:Something isn't ringing true for me, the attached document in the OP is dated 2001, we need to see the FAA document. In my experience the two civil agencies usually "accept" each others STC approvals with the occasional minor caveats. The acceptation to this are FAA 337's or Canadian LSTC's. Transport Canada (TC) only recognizes fully approved FAA STC's and similarly I don't believe the FAA recognizes TC LSTC's.
Mapleflt wrote:Very unfortunate; makes it a somewhat useless STC, adding weight for a minimal gain.
Zzz wrote:Mapleflt wrote:Very unfortunate; makes it a somewhat useless STC, adding weight for a minimal gain.
Isn't it like 4 feet extra wingspan? Doesn't that provide a lower speed takeoff/landing?
mtv wrote:There's no question that the wing extensions improve takeoff performance, especially on floats. That benefit probably would be minimal with a stock engine in a 170, though.
Mapleflt wrote:Exactly so for this to be a "financial" success for the developer the final "approved" STC be it FAA or TC could very well spell out the requirement for "180 or greater".
akgreg wrote:Mapleflt wrote:Exactly so for this to be a "financial" success for the developer the final "approved" STC be it FAA or TC could very well spell out the requirement for "180 or greater".
Maple Syrup,
I have the final approved paperwork. I have the kit. There is no “180 or greater” language used. I’m pretty sure the quote I posted from Paul at Wing-X was very clear about what you get. 50 lbs.
