Backcountry Pilot • Cessna 180 jack
Cessna 180 jack
29 postsPage 1 of 21, 2
Cessna 180 jack
I saw a handy looking jack, for a 180/185; that I thought would be useful in changing from skis to wheels. I thought I saw it on this site, not long ago, but can’t find it through the search function.
As I recall it utilizes a bottle jack, and offsets far enough from the wheel to allow for the skis.
Does anyone know the jack I’m referring to?
Thanks,
Aqua
aqua offline
Re: Cessna 180 jack
This reply doesn’t speak directly to your question, but after fiddling with every possible teeter-floooper over the years, this is BY FAR the best airplane jacking arrangement that I’ve found. Unlike a compression jack, It’s super stable and the shop crane has myriad uses. Also seems like it could work with skis. Only disadvantage is it doesn’t work out in the field too well.
Scolopax offline
Re: Cessna 180 jack
Arctic Flyer offline
Aircraft: 1974 C-180J
Re: Cessna 180 jack
Scolopax wrote:This reply doesn’t speak directly to your question, but after fiddling with every possible teeter-floooper over the years, this is BY FAR the best airplane jacking arrangement that I’ve found. Unlike a compression jack, It’s super stable and the shop crane has myriad uses. Also seems like it could work with skis. Only disadvantage is it doesn’t work out in the field too well.
Do you some some close up shots ?
corefile offline
Aircraft: Cessna 180 - sold
Re: Cessna 180 jack
Not super close up shots, but that’s how I do mine with spring gear:
https://backcountrypilot.org/community/ ... 0?start=80
About halfway down the page. I use a simple friction hitch (maybe a Prusik? I can’t remember exactly how I tied it last time.) with some Amsteel cord between the gear leg and the engine hoist.
I can dig out an old hard drive to find close-up shots if you want. I need to get it out and put them on our photo cloud anyway.
Re: Cessna 180 jack
Arctic Flyer, that’s the one.
Is that store bought? Do you have a name or link?
Thank you,
Aqua
aqua offline
Re: Cessna 180 jack
aqua wrote:Arctic Flyer, that’s the one.
Thank you,
Aqua
I’d like to source one of those as well.
Re: Cessna 180 jack
Shirtfinalfab.com
Happy jacking!
Re: Cessna 180 jack
Arctic,
That link does not work. I'm interested as well.
MW
185Midwest offline
Aircraft: C-185
Re: Cessna 180 jack
aqua offline
Re: Cessna 180 jack
There's also the av-jack, sold by TLGW.
https://tlgw.aero/tlgw-specialties/av-jack
I prefer to use an engine hoist, per scolopax's pic.
Re: Cessna 180 jack
No closeup photos handy. It’s just a 2000 lb strap with a single full wrap around the gear leg. It cinches down tight and is 100% stable, which compression jacking arrangements are not. Quick, easy and confidence inspiring.
Scolopax offline
Re: Cessna 180 jack
Here's what it looked like when I used the strap.
Re: Cessna 180 jack
motoadve offline
Aircraft: Cessna 182P
CJ 6 Nanchang
Cessna 170B
Re: Cessna 180 jack
Arctic Flyer wrote:
Of those pictured I'd say this is the only one that stands an outside change of working for a change from wheels to skis. All others don't like they would provide adaquate clearance for the width of a straight ski or wheel ski
Re: Cessna 180 jack
This works well for bushwheels and skis. It’s pretty slick and it seems like I’m usually changing on a muddy ramp.
Re: Cessna 180 jack
I like your load distribution modification =D>
Re: Cessna 180 jack
motoadve wrote:This are very nice.
Good luck using that for skis like the OP is looking for...
Re: Cessna 180 jack
This is a readily available 6 ft tow strap, wrapped around the gear leg, inside the brake line.
Lsw offline
Hatz biplane
Re: Cessna 180 jack
Safest, most stable way I have found to change tires.
Lsw offline
Hatz biplane
