Backcountry Pilot • Cessna Grab Handles
Cessna Grab Handles
59 postsPage 3 of 31, 2, 3
Re: Cessna Grab Handles
I tried but failed to post a picture. I will attest Casey makes a fine product. I've ordered 5 sets from him in the last couple years
JC
185Midwest offline
Aircraft: C-185
slow18 wrote:[email protected]
Thanks!
corefile wrote:
nickelb wrote:I wonder if these would fit a 180
I'm considering buying them - has anyone tried these to see if they will fit?
https://amzn.to/3roteeN
Those look nice and they have a good color selection - for that price and the generous Amazon return policy - only way to know for sure is to order a set and give them a try to see if they will be to tight or not, meaning can you get you hand between the strap and the interior of the plane to get a grip. They look like a great affordable option.
There is also the not so affordable option of these - the picture on the website is actually of mine - I worked with these guys (paracord guy and Bushliner) to make my set and now they sell them. They are not the cheapest - but give you a more stock-ish look and those titanium ends are nice. Anywho they are a full AMU for each per handle… so again not the budget choice, but another option.
https://www.lostriverparacord.com/Aircraft_Grab_Handle_p/cg800.htm
Wait, an AMU as in an Aviation Monitary Unit? $1k? Man I can’t afford to fly Back Country. A factory new leather wrapped grab handle for a Cirrus is 60 bucks. Launching the 185 off a cliff now
Ross4289 offline
Aircraft: 185
Ross4289 wrote:....Wait, an AMU as in an Aviation Monitary Unit? $1k?....
$100 each, per the lostriver website.
Someones confusing the wife AMU of $100 with the actual AMU of $1000
I think I did this correctly. Here are Caseys' handles.
I really like them.
JC
185Midwest offline
Aircraft: C-185
Here are those mounted on a 1966 J 182
Mantoga offline
Aircraft: C-182J
daedaluscan wrote:Someones confusing the wife AMU of $100 with the actual AMU of $1000
I need to remember that one…. =D>
Flying Dave offline
Aircraft: Aviat Husky
Mantoga wrote: Here are those mounted on a 1966 J 182
Those look good, but amazon sez 11" long.
The mounting holes in my 53 180 are 11-1/4" apart so don't think they'd fit.
Casey's are probably the way to go, if you don't like / don't have the stock ones.
Hmmm to short for my 56 180 might have to send them back :(
Glidergeek offline
Aircraft: 1968 P206C
DG 400
Casey is a fellow pilot and drives a 180 I believe and fishes. Why not spend a few bucks on a known quantity and get in touch with him. You will not be disappointed. He get's it and provides a quality product.
JC
185Midwest offline
Aircraft: C-185
I would respectfully suggest you choose color for these things……hands are grubby things, so these things tend to change color over time.
FWIW I just measured the stock (?) "assist straps" out of my C180. They measure just about 12-1/4" center to center of the mounting holes.
My IPC shows 3 different part numbers for the "strap- assist", including 2 part numbers allegedly both applicable to my 53 model, so your mileage may vary.
Great looking and functional. What screws did you use? Thanks
Bosi72 offline
Aircraft: 1960 Cessna 172A
Stumbled across this forum and thread and thought I would share. I’ve been making assist handles for a couple years. I’ve always used paracord and stainless d-rings until recently someone asked if I could make them a set using Kevlar. They sent me the materials to use including the canyon dancer strap rings for mounting ends. I really like the strap rings and have been searching for something better than the d-rings. Anyway, to the point of the post, since kevlar doesn’t melt like paracord had to come up with a way to finish and secure the cord ends. What I did was put a dab of epoxy adhesive on the end and then used heavy duty shrink tube I got from a local electrical supply store. Thought it worked pretty slick and wanted to share.
KnottyByNature offline
KnottyByNature wrote:Stumbled across this forum and thread and thought I would share. I’ve been making assist handles for a couple years. I’ve always used paracord and stainless d-rings until recently someone asked if I could make them a set using Kevlar. They sent me the materials to use including the canyon dancer strap rings for mounting ends. I really like the strap rings and have been searching for something better than the d-rings. Anyway, to the point of the post, since kevlar doesn’t melt like paracord had to come up with a way to finish and secure the cord ends. What I did was put a dab of epoxy adhesive on the end and then used heavy duty shrink tube I got from a local electrical supply store. Thought it worked pretty slick and wanted to share.
Looks great! How can a guy order a set?
My name is Tyler
Call/Text: 907.952.6531
Email: [email protected]
The heat shrink is brilliant. Thanks for the tip.
Looking at the grab handles I have (stock 185), I wonder what the screws go into. Is there a nut plate that’s secured back there? A nut with only plastic holding it all in? A nut on the other side of the pillar, waiting to disappear when the screw is removed?
Recovering from a recent surgery, I got so bored that I started making paracord bracelets. This is a logical next step, provided the attachment is workable.
StuBob offline
Aircraft: Cessna 185 Skywagon
StuBob wrote:The heat shrink is brilliant. Thanks for the tip.
There is a nut plate riveted into the door post. So just pull the screws out and out them back in. No need to worry about the nut falling down.
