I bought a bunch of eye rings to use as tie down points in the baggage area. The mount hole is bigger than I wanted but an oilite bushing fits perfect allowing a #10 screw or bolt to be used. A bent thin washer keeps the ring from rattling while still able to rotate.
The cord I used is an 1800 pound test kevlar looped over six times. Not that I needed handles rated to ten thousand pounds... it just gave me the thickness I wanted and the kevlar is burn resistant. Also, in a survival event I have two 20 foot sections of 1,800 pound test available.
These were made 11.5 inches on center. 12" on center seemed a bit too long and 11.5 was just barely long enough. The Kevlar does NOT stretch like paracord will. The first photos are of paracord. I switched to kevlar after thinking about flame resistance and grabbing molten paracord in an emergency.
The eye rings are here
https://www.amazon.com/Canyon-Dancer-Ti ... B0068ESQTY
And the kevlar is here
https://www.amazon.com/gp/product/B07BF ... UTF8&psc=1
They aren't the cheapest grab handles you can make but they will last a really long time.
