Backcountry Pilot • Engine is toast turned into full plane project
366 postsPage 9 of 191 ... 6, 7, 8, 9, 10, 11, 12 ... 19
Re: Engine is toast turned into full plane project
A1Skinner wrote:
airChris wrote:I like the oil quick drain installation... whose is it?
I’d like to do something similar, but the quick drains I’ve used (all 2 of them) state that hoses cannot be left connected.
Chris
Looks like the aeroquip.
Correct - its the aeroquip - and that hose can be left on, installation instructions say you can trim it to the length you want or you can remove it if you want.
"NOTE: Hose may be trimmed or
removed."
corefile offline
Aircraft: Cessna 180 - sold
panel is starting to get installed.. Dual Dynon Skyview HDX's
corefile offline
Looks great.... except that small backup Dynon in the middle.. why haven't they improved the aesthetics on those to match the HDX's?? haha
You're going to have an incredible plane.
Is the hole below the small Dynon is for an engine monitor?
Which one are you going with?
Looks super!!!! I'm very interested how the panel is going to match up with the old glare shield area shape. Would be nice to have a shot like standing on a tire looking down in that area.
asa wrote:Looks great.... except that small backup Dynon in the middle.. why haven't they improved the aesthetics on those to match the HDX's?? haha
I agree 100% - that is the Dynon DA10 and its long in the tooth and fugly (but required for the STC)! Rumor is there is a replacement that matches the HDX on the way and it will be a slide in replacement. I talked to Dynon and they would not confirm or deny, but agreed that the DA10 has been around for a long time and its logical to assume it will be replaced..
Hotrod180 wrote:Is the hole below the small Dynon is for an engine monitor?
No, I'm using the Dynon engine monitoring module, so I can display my engine monitoring on either screen, as a ribbon, half screen or full screen.
That space below the Dynon D10A - is for my audio panel PMA 450B and my future IFR nav unit Avidyne IFD 440 - tray, wiring harness, and GPS antenna will be already installed, so I can just slide in the IFD 440 down the road.
180Marty wrote:Looks super!!!! I'm very interested how the panel is going to match up with the old glare shield area shape. Would be nice to have a shot like standing on a tire looking down in that area.
Thanks - I'm really looking forward to this. There is no old glare shield, it's all new - here is a pic, there is still the grill on the top to be installed, and the glare shield will attach on top of this (that open hole in this pic is one of the places the glare shield will be attached via a nut plate, and it will all be perfect fit and finish.
corefile offline
Sportsman STOL going on and then headed for the paint booth, plane is in the background - going to strip as well and paint (the paint on there was an attempt to paint over old paint - changed the plan and doing a proper paint job)
corefile offline
Looking awesome! I vote for a nice clean older factory scheme. They always look great!
I'm curious what your paint scheme will be?
hotrod180 wrote:I'm curious what your paint scheme will be?
Posted it a while back, but here is the paint scheme I'm going with.
corefile offline
Thats going to be cool!
Have you thought about Stene Aviation Quasar wingtips? I just installed the whole enchilada. All AERO LED, every light. If I can figure out how to post a video I will. I really want to be seen, day or night.
MW
185Midwest offline
Aircraft: C-185
185Midwest wrote:Have you thought about Stene Aviation Quasar wingtips?
MW
Yep I ordered the Quasar wingtips same time as the Sportsman. I had already switched all my position/strobe lights over to LED, and wing landing/taxi lights. Adding the quasars and replacing / adding interior lights with all LED and under wing courtesy LED lights. When it's all done will be 100% LED as well.
corefile offline
Beautiful!
Aryana offline
Aircraft: 1955 Cessna 170
You will be very very happy with the lights day and night!
MW
185Midwest offline
Aircraft: C-185
New firewall blanket, rudder pedals, rudder pedal tube, and hardware.
corefile offline
So sanitary [emoji1360]
Aryana offline
corefile wrote:New firewall blanket, rudder pedals, rudder pedal tube, and hardware.
I think you’ll find those rudder pedals to be a really nice addition. The pedals in my 170 were shot, so I replaced with a set of these, and I found it MUCH easier to avoid inadvertent braking with rudder application. Cessna did a good job redesigning the pedals, it turns out.
Fantastic job on the restoration!
Wow again!!!! I need a blanket like that for my "54" and this is the best picture yet of the glare shield install. Totally understand what you're doing now!!!!!
glacier offline
Paul, what's it looking like re completion date?
