hotrod180 wrote:corefile wrote: looking forward to getting the 180 stripped, primed, and painted.
Is Bushliner gonna do the painting also?
Yep - they just finished installing their new paint booth.
corefile wrote:Another little mechanical issue that was fixed as part of this.
Ah... the old upgrade your generator to a 70 amp alternator - but leave it on a 50 amp circuit breaker install method. And yes I did have that circuit breaker pop before.
Nice, 70 AMP ALTERNATOR, I gots power to spare
Not so nice - they installed it and kept the original 50 amp circuit breaker
bart wrote:...... I've done two of these Plane Power Alternator conversions on 180's, and the main reason was to reduce weight and add reliability, not to correct a current deficiency. Both times, I've kept the original 8ga wire size (not the original wire mind you)and upgraded to a newer C/B (50A for 8ga wire)
hotrod180 wrote:bart wrote:...... I've done two of these Plane Power Alternator conversions on 180's, and the main reason was to reduce weight and add reliability, not to correct a current deficiency. Both times, I've kept the original 8ga wire size (not the original wire mind you)and upgraded to a newer C/B (50A for 8ga wire)
but it's mostly all low-draw stuff like LED lighting & solid state avionics & instruments.
Is a 70A alternator really required?
Used to be a 50 or maybe 60 amp alternator conversion was the norm,
nowadays it seems like they're going bigger, for example this 70A Plane Power.
I understand that everyone's running a lot more electrical stuff,
My old C180 still has a 35A generator & it seems to keep up with everything just fine.
Couldn't somebody make an STC'd lower-capacity alternator that's smaller & lighter?
I see them for experimentals but not for certified aircraft.
hamer wrote:......I've been very happy with my 40amp B&C alternator. But I'm not sure it works on these bigger engines. It's a real alternator and voltage regulator, not like their little ones.
https://bandc.com/product/bc400-alterna ... -pma-wlt1/
Nushi wrote:
What do you have going on under the PAR200B? That the autopilot? Looks fantastic! Love everything, especially that switch panel.
Stew0014 wrote:Is there a program for designing your own cockpit display or was this photoshop?
That’s what decades of dirt trapped between the rubber seal and fuselage will do, forms a lapping compound and grinds away. A fresh rubber seal and clean paint it’ll be good to go.corefile wrote:While stripping the plane for paint - found that the vertical stabilizer had worn into the fuselage. Checking the depth to see how deep - I believe 20% of the thickness of the material is the limit? Anyone else have this problem? Do you go without the black rubber gasket - mine had hardened over the years into a hard plastic, and must have eaten into the fuselage? What are the options to the rubber gasket - I've seen some 180's that have just left them off, any other options?
