Lost almost 10 pounds having my rear seat redone a few months ago as well.
Cary wrote:Going back to my thoughts of less gas rather than lightening seats, I notice that the best weight savings listed is 4.1 lbs. per seat--less than 1 1/2 gallons of gas for two. If your seats need replacing/repairing/recovering anyway, OK. But if they're OK, just to save the equivalent of 9 minutes of fuel? Nah, not worth it.
robw56 wrote:Cary wrote:Going back to my thoughts of less gas rather than lightening seats, I notice that the best weight savings listed is 4.1 lbs. per seat--less than 1 1/2 gallons of gas for two. If your seats need replacing/repairing/recovering anyway, OK. But if they're OK, just to save the equivalent of 9 minutes of fuel? Nah, not worth it.
It all adds up. All the weight removal I did on my 170 took off 60lbs from the empty weight. That translates into better takeoff and climb performance or 60 more pounds of stuff I could legally take with me before I hit gross weight.
Hey Greg, what do you mean when you call them bladders? Do they just slip onto the frame? Could he do them up without the seat frames?Bigrenna wrote:I've been involved with a bunch of seat restos now and the savings is all about the same as AK Greg mentioned. Going from stock springs/padding/vinyl to nylon blatters (as Ron Matta calls them) will save you 5lbs per seat. And that is with leather. I have done a bunch of artwork for these seats which I have given to Ron for anyone to use. Its pretty flattering to see these designs out there, so if the gestalt resonates, feel free...
Just my .02, but there is NO way I would approach a seat refresh w/out tossing the springs in the garbage.
RE: orig seats. I like the look of the round back, but the square backs are more comfy. There are 3 versions of the square back. Non, and two articulating. the non articulating square backs are just every so slightly heavier than the round backs - not worth worrying about if you want comfort.
If you want articulating, go with the mid year versions as the later articulating are just too freaking heavy.
Good luck!
A1Skinner wrote:Bigrenna wrote:what do you mean when you call them bladders? Do they just slip onto the frame? Could he do them up without the seat frames?
A1Skinner wrote:Ok. Interesting. Thanks for filling me in. Looking at options for my 206 seats.
Ya for sure. I planned in pulling them all apart and replacing all the roll pins and such, then pulling the springs off and going the ceconite route.Bigrenna wrote:A1Skinner wrote:Ok. Interesting. Thanks for filling me in. Looking at options for my 206 seats.
Regardless of the upholsterer you use, I would break em down completely yourself and then have them powdercoated locally. Way cheaper than having that part done by a seat guy. Also, they typically paint the sub frames assembled, which is a bit booty... LOL
jaudette wrote:I saved 22lbs by redoing my seats. I took out all the springs and old heavy foam and bought a leather kit and did it myself. Took me about a day is all.
I'm pretty happy!
Jim
