Mon Apr 29, 2019 12:56 pm
Earlier I said I'd do a writeup on my panel design & thoughts; this all started as a simple comm swap for my broken Narco 810 and ADS-B install... it has snowballed to a major degree. It should be noted that I haven't really trusted my vacuum-driven instruments for the last couple years based on how fast the DG precesses and how long (~10-15 min) my AI takes to level out. I haven't cut anything yet, I'm still in the design phase. I'm going to assemble as much as possible on the bench, so that the plane has minimal downtime.
I quickly realized how expensive this project could get if I didn't write out my requirements and nice-to-haves (goals).
My requirements are as follows:
1.A. Replace comm radio.
1.B. Add ADS-B Out capability.
1.C. Overhaul or replace the AI/DG.
My goals are as follows:
2.A. Vacuum system delete, go electronic.
2.B. Panel modularity for ease of work and future upgrades.
2.C. Reuse any avionics/instruments that I already have and are not broken to reduce cost.
2.D. Modernize the electric system interface & capability.
To satisfy Req,1.A, I bought an operable Icom A200 & tray at an excess part/old tools auction from my employer.
To satisfy Req,1.B. I got a Garmin GDL82 to piggyback off my current Garmin GTX327 transponder.
To satisfy Req,1.C. I could overhaul my vacuum instruments and be done with this whole project, but I that's too easy! Instead, to make my life more complicated I plan on purchasing a Garmin G5 and deleting the vacuum system entirely -- check off Goal,2.A.
Again I could stop here and make a shabby looking cover plate for the old DG, but I have never liked the panel in this plane.
The panel design is segmented into pilot-side w/ standard sixpack layout, center-stack, and copilot-side. Each segment will be front mounted via nutplates, so I can easily access the rear side of any avionics/instruments while sitting in the front seats rather than laying upside down under the panel (that sucks!) -- Goal,2.B. complete.
I'd love to add an EI CGR-30P, but at this time it's just not in the books. Staying true to Goal,2.C. I'm relocating my tach to the standard VSI location (G5 has integrated VSI) and my dual oil pressure/temp gauge to the standard DG location. In the future, I could put a digital engine monitor in the VSI location and add a second G5 (integrated HSI) or equiv in the DG location, this in addition to a IFR GPS/Nav/Comm would give me instrument-flight capability.
As others have mentioned about electronics and their useful lifespan, I plan on utilizing a RAM mount for an iPad Mini on the copilot side of the panel, directly next to the radio stack. I don't necessarily plan on mounting my phone (Galaxy S8) on the panel, but it was easy to add in CAD to check fitment, so that I have the future option for a standard smartphone to be RAM mounted on the pilot side upper left corner next to the six-pack. Concerning panel docked portable electronics, I did model my Garmin Aera 510 in an Air Gizmo, because I already have that in my stack and I like it (XM weather & radio). If I upgrade or want to change my radio stack in the future, that's easy because the Air Gizmo fits in the standard stack, so any other avionics or a simple rectangular block-off plate will drop in.
Goal,2.D. will arguably produce the most work definition out of any of my requirements/goals. Currently there is a small subpanel w/ 8 circuit breakers above the pilot's left knee, only the lights have switches (no power groups like an avionics master), and there is one cigarette lighter stlye power port. I will move my remote ELT switch beneath the txp and add a new panel-mount intercom (for years I've used a 4pl portable, temporarily attached beneath the panel). A new copilot-side CB subpanel will be mounted to the copilot segment, so I can access each group individually. It looks like I'll need 14 CBs, but it will be easy to add more if necessary.
Right now, I plan on adding 5 switches (shown under the iPad Mini).
1. ADS-B anonymous off/on
2. Accessory power group (cigarette lighter, panel mounted dual USB power ports) off/on
3. Auxiliary power group (USB power ports behind the panel: iPad Mini, Garmin Aera 510, Stratux ADS-B In) off/on
4. Avionics power group (Icom A200 Comm, Garmin GTX327/GDL82 Txp/ADS-B Out, Sigtronics SPA-4S Intercom) off/on
5. Instrument power group (Garmin G5, turn & bank, fuel level gauges) off/on
- cap1-01-C.PNG (456.66 KiB) Viewed 3193 times
