Backcountry Pilot • IO-360 vs IO-360
IO-360 vs IO-360
27 postsPage 2 of 21, 2
Re: IO-360 vs IO-360
Can you provide further on the Isham STC, it’s a new player/name for me !!
It's used on a lot of Cessna R172K Hawk XP aircraft (which were actually built by Cessna on their C175 Type Certificate).
http://planetools.com/cessna-r172k/
The Cessna T-41 military trainers also came right out of the factory with Continental IO-360 motors rated @ 210 HP.
I've also heard that Isham 210hp conversions have been used on some Swift model airplanes, but, I'm not certain.
There may be others?
BluNosDav offline
The Isham STC is only to increase the rated horsepower of the HawkXP from 195 to 210 by changing the prop stops.
It is not to install the engine.
Tom Anderson holds the STC to install the engine and it's already rated for 210 on his STC.
Bagarre offline
david j nelson wrote:I looked at all 3 engines when doing my conversion on Cessna 170 .The continental was a little heavier and more complex ,and then the Lycoming was ok but it does shake a bit , then I was shown a superior engine and doing the same thing and it’s vibration and quality control exceeded the Lycoming The superior was fitted to my aircraft and what a difference . I have the privilege of flying a 170 with both engines fitted [lycoming and superior] . The 170 with the superior feels stronger to fly and has more power. The 170 with the superior has a sensenich prop with 60in pitch while the Lycoming 170 has a fixed pitch mt prop [58 ins but not to sure] . Fuel consumption in cruise with the combination of superior/sensenich has a much better fuel consumption. Down to 34 liters a hour in cruise at 8000ft . The Lycoming engined 170 ,cruised at 38 to 40 liters a hour at 8000ft. The superior engined aircraft weighs 1428lbs and the Lycoming engined aircraft weighs 1490 lbs.
I think we're all curious to hear what this "superior" engine is. You've certainly peaked my interest.
Cheers
heli_adams offline
LOL
*piqued
I'm curious what approvals/STCs were used for those engines with the fixed pitch props? As to weights, it's kind of meaningless to compare weights of old airplanes....they are likely not very identical in equipment. My 170 with Lycoming O-360 and MT Constant speed weighed well under 1400.
Just curious to know what the C-172 conversions would cost? The Lycoming IO-370 conversion seems to be a great option. Also I'd be interested to know what the IO-390 weighs compared to the Continental IO-360. Has anyone flown the Hartzell Trailblazer propeller on this forum? I would like to know how it would perform against the MT 2 or 3 blade? What is the price comparison? Thanks in advance!
cook11 offline
Aircraft: Amateur-Built Pacer
Cessna 182RG
