Helio's watch out is right!
Looks fantastic.
You must be giddy with excitement. Good for you!
Renegade wrote:How noticeable is the decrease in roll rate?
Barnstormer wrote:Renegade wrote:How noticeable is the decrease in roll rate?
My 185 has an Aileron/Rudder Interconnect which means with normal roll rates I can keep my feet flat on the floor (off the rudder pedals) and the ball stays centered. The first thing I did in the test flight was check the roll rate, and yes, without using my feet the roll rate is a little slower.
But fly it like I do the SQ-2, with liberal amounts of rudder that takes the ball off center momentarily, and you could easily snap-roll the 185 even after the wing mods. So for me it's not a problem, and probably better so my feet won't get lazy. The Sportsman also comes with Aileron gap seals which helps with the roll rate. After a few minutes of flying it's a non-issue.
RKTX wrote:Very Interesting! Are the ailerons noticeably heavier or is it just a slower rate?
Barnstormer wrote:Funny thing is, I didn’t even know I needed a new prop.
55wagon wrote:..."there, I'm done, she's perfect".
Barnstormer wrote:55wagon wrote:..."there, I'm done, she's perfect".
Put that on my tombstone when the time comes - will ya?
