mtv wrote:So, Phil, why's the tail off the beast in the first place? Hell, with the rain you guys been getting, you need to think floats......
So, are you talking to the guys at Flight Resource about an MT three blade....lighter, better, etc....ya know..
When I was up at Willie’s I asked him to look the 185 over and tell me if he thought there was anything that needed addressing. He had two suggestions. First was the flap tracks. Although there was nothing wrong with them he suggested installing the McFarlane Flap Track Kit so there would be no problems in the future. Done.
http://mcfarlane-aviation.com/Products/?PartNumber=MCSK100&A relatively easy install, especially with their Flap Roller Installation tool.
http://mcfarlane-aviation.com/Products/?ID=96323566&PartNumber=970&The second suggestion was to overhaul the tail assembly. He came to this determination by grabbing the horizontal stabilizer and attempting to move it fore and aft. It had like a 1/32” of travel. Willie told me I should do this ASAP as currently the wear was in a couple of plastic bushings and not addressing it would get really expensive once the wear got into the metal. So off the tail came. Since its off I’m replacing every single nut, bolt, washer and bearing. Once or twice a year I’ve had to tighten the bolts that hold the stinger on so we pulled it as well and are replacing nuts, bolts, washers and bushings. Speaking of washers, the two that go between the cradle and rubber bushings were missing. Guess for the last person who had the stinger out it was too much of an effort to fish the washers in.
So... the next “next to the last mod”, the prop. I’d love to go to a more modern blade design, and would surely like the weight on the nose not to increase, but, for my 185 the MT prop is restricted to 2,500 rpm max.
At Sea Level that’s a drop in horsepower from 300 to 255. At 6,000ft pressure altitude the drop is from 240 to 205.
And according to Cessna the difference in climb rate between 2,850rpm for 5 minutes, and 2,700rpm continuos is 35 ft/min (with the 82” 2 blade that was originally installed on my year/make/model 185). Although this number isn’t for the prop I’m currently running, nor its replacement, I think it does illustrate the difference horsepower/rpm makes.
If the MT was rated at 2,700rpm the choice would clearly be the MT. I know blade design can make a big difference but I just can’t get past the horsepower thing. Right now I’m heavily weighted (pun intended) to the 88” Mac 3-blade. Why the 88” over the 86”? I suspected the 88” would out perform the 86” at altitude, and Willie confirmed that (he has two A185F’s, one with the 86” and one with the 88”, and both he and his Dad feel the 88” out performs the 86” at high DA).
Price has no bearing on the decision as both the MT and the Mac cost $15k.
Floats would be awesome, at least until the Cigarette Boats take over the lake again. Austin is now the 11th largest city in the U.S., and certainly one of the highest income. Can't imagine how many boats and jet skies will be sold in the next year or two.
