redlinemike wrote:I just had a similar problem from a different mechanic on Chena Marina. I got my Citabria out of Annual expecting everything to be great only to find on my inspection that the hose that connects the intake to the carb box is just jammed in there and not routing the air from the intake to the carb box, so that as soon as I went to fly I am sure it would have sucked it into the carb box and suffocated the engine on take off, or worse on a go around. The aircraft is fouling plugs like crazy so I have a different mechanic look at it and discover the plugs are gapped to over twice what is allowed. The mixture screw is completely bottomed out to maximum. The carpet has just been jammed in there and is not layed in around all the trim and other pieces like it should be, he has repaired on hole in the fabric and the other he taped then never silvered or painted it. There is a new hole that I am pretty sure was not there before, and a ton of other little things.
After he tells me I am done and I move the aircraft out of his yard while he is finishing up the paperwork only to get a call that he forgot to do some inspection on the engine and he will not be able to do it for a few weeks so my choice is to let it sit grounded for a few weeks or pay another mechanic to take off all the cowling and parts that were already off during the annual to finish up the last inspection, then pay for all those parts and cowling to be reinstalled a second time.
What options do we have for dealing with something like that? More than me just getting screwed by the guy, it is just unsafe for people to be sending out airplanes like this.
I realize that the pilot in command is responsible for determining whether the aircraft is in condition for safe flight, but how can we as PIC's be sure of that when we do not do our own maintainence and in most cases would not know what to look for anyway. I am not allowed to pull apart the aircraft and look at the insides of things but I have to determine if it is air worthy? At what point does the responsibility fall on the maintainer?
Mike
redlinemike wrote:What I know how to do and what I can do legally are very different things. Of course I can handle the basics lined out in part 43, but I am refering to all the stuff I am not allowed to do.
BobWhite wrote:As I read the regs, you can do most every regular repair and inspection, if you are under the supervision of an A&P who will approve the work. In fact, quite few shops have mechanics who are not licensed, but whose work is "signed off" after they are done by the ower or manager who is an A&P and/or IA. If I could not work on my plane, I wouldn't have one.
bush pilot wrote:very similiar to this accident
http://www.ntsb.gov/ntsb/brief.asp?ev_id=20010426X00818&key=1
a64pilot wrote: This guy is a nut and I think they are afraid of him.
a64pilot wrote:The National Transportation Safety Board determines the probable cause(s) of this accident as follows:
the reverse rigging of the aileron flight control system resulting in aileron deflections opposite that of the pilot's inputs which lead to an uncontrolled descent into the terrain. Factors include the pilot's failure to detect the misrigged ailerons during his pre-takeoff flight control check.
What this say's unless I miss something is the the probable cause of the accident was the reverse rigging of the ailerons. A contributing factor was the pilot failing to detect the mis-rigging.
The pilot will always be the last link in the accident chain, but there is no way the cause wasn't the mechanic.
Actually what the NTSB said is the same thing most of us said
Those are my guys! I love them! Everybody in Fairbanks is busy, the best you can do is get someone who is busy and backed up BUT does good work.mtv wrote:Mike,
U
Next time, take it to Nathan and Mark at Chena Marina Air Service. Young guys with a really good customer oriented attitude.
If they have time....
