akgreg wrote:Keith, you NEED a Sportsman's cuff. Then you NEED to put VG's on it. You will NEED to control your smile from that point forward.
kg wrote:...I've vowed to not go down the rabbit hole of "I need that mod...." but a friend up at Denali just told me that I should fly his 182 with the Sportsman's cuff before I rule anything out. There must be something to it...
kg wrote:Thanks Greg! That's good info. Mine is a '75 so has the Cessna camber lift wing. I expect avgas will be the best money spent on mine for a while.
corefile wrote:jrollf wrote:Another good reason is the 'standard' USB plug is slowly becoming obsolete in the electronics industry, there is a move toward the smaller 'USB C' connector.Barnstormer wrote:DeltaRomeo wrote:Why don't you just install numerous USB charging ports instead? You know thats what it going to be used for...
That's an excellent question. And the answer is because Garmin hasn't yet learned what a USB connection is. Both my powered inRreach mount and my GDL 39 cables have old-school cigarette lighter plugs. Hopefully some day they'll figure it out, but probably not till everyone else is charging things through the air.
I personally like to keep the power plug (aka cigarette lighter) because I can always find a charger that adapts to whatever the 'latest' plug that my gadgets have. Once/if the USB plug becomes obsolete you would have a useless plug in your airplane.
That is nonsense about it becoming obsolete... since you are only using the USB port for power, not actual data - there will alway be someone that will make an adapter .... just like for the cigarette lighter. Most new cars don't even come with a cigarette lighter anymore, but almost all have USB - that alone will keep usb peripherals alive for a very long time. And as far as USB C - that is why I went with this http://www.aircraftspruce.com/catalog/elpages/mcitrueblueta202series.php it gives me both USB types, plus I have cables that are Dual outputs (USB and Type-C). https://www.amazon.com/gp/product/B075WY6VQ8/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1. I mean its a bit hokey - you can even get a USB to female 12v lighter socket cable https://www.amazon.com/ARECORD-Cigarette-Lighter-Socket-Converter/dp/B01J67JIOQ for those unicorn devices that have hardwired lighter socket power(without an option to buy it with USB). My only point here is, USB for power it not going to go away for a very very long time. And whatever replaces it, would also replace the lighter socket (like power over air).
akschu wrote:I have this one:
https://amzn.to/2Ede2JT
It works well, seems reliable, and gives me a battery voltage which is handy. When my alternator failed, it was very obvious, and when I was trying to debug if it was the alternator or the regulator in the field, this little charger with a small length of wire was used as a basic voltmeter.
schu
Bigrenna wrote:FWIW... Some of these non-TSO gizmos can wreak havoc with RF interference. I trouble shot a portable GPS for over a week with Garmin until finally figured out the culprit. It was a cigarette USB.
DeltaRomeo wrote:
That is nonsense about it becoming obsolete... since you are only using the USB port for power, not actual data - there will alway be someone that will make an adapter .... just like for the cigarette lighter. Most new cars don't even come with a cigarette lighter anymore, but almost all have USB - that alone will keep usb peripherals alive for a very long time....
