bat443 wrote:.... I installed the BAS handles in a 170B, used screws so that I could take the handle out if extensive work was ever need on the aft bulkhead.
Rivets look much better than screws IMHO, but this makes a lot of sense.
StuBob wrote:A tip on the handles: I have orange safety tape wrapping the ends of mine, which has kept me from bumping into them with my....um....upper thighs.
Nope, clears fine.wagonflyer wrote:Looks great. No problems fitting with the V-brace in-place?
Another good reason is the 'standard' USB plug is slowly becoming obsolete in the electronics industry, there is a move toward the smaller 'USB C' connector.Barnstormer wrote:DeltaRomeo wrote:Why don't you just install numerous USB charging ports instead? You know thats what it going to be used for...
That's an excellent question. And the answer is because Garmin hasn't yet learned what a USB connection is. Both my powered inRreach mount and my GDL 39 cables have old-school cigarette lighter plugs. Hopefully some day they'll figure it out, but probably not till everyone else is charging things through the air.
Bigrenna wrote:...Glad you had it easy Phil. LOL
DeltaRomeo wrote:Apparently Maule is not the only manufacturer that identifies the "Mic" location with "Mike"
