Heh. You might get me into the baggage compartment, but I’d probably get stuck much past there!
#ChunkyMonkey
) and maybe wipe things down and clean up anything that needed it. When I opened up the cover to take a peek behind the extended baggage I thought how in the hell does anybody get back there over all the cables, and, once installed, get to anything past that tube once it is installed????
You hire a 6', 150 lb guy to work on it. Haha. At school I looked around and thought most guys can't get into small planes. Me, I fit down the tail easy, and I'm not clausterphobic which helps. Good light is important.Flying Dave wrote:As a new 180 owner I was thinking after we bought it that I would get some blankets/pillows to lay in the belly and maybe crawl back there to inspect (at 6'2" 220 lbs) and maybe wipe things down and clean up anything that needed it. When I opened up the cover to take a peek behind the extended baggage I thought how in the hell does anybody get back there over all the cables, and, once installed, get to anything past that tube once it is installed????
Oh, and I am enjoying this thread. ESPECIALLY since it is not my money.
Barnstormer wrote: BAS Tail Pull. If all goes well this is tonight's mod. Requires a skinny guy to go into the tail.![]()
The last one I installed had 6 rivets per side.Bigrenna wrote:
Phil, Im confused as to the pic... What is that ring that is screwed on the outside of the skin? The tail pull handle should be riveted and the entire assy on the inside. Looking from the outside, there should just be a hole and 5 rivets.
I'd also recommend opening up that center hole much more. Otherwise it will scratch the handle... but more importantly, when force is applied, it will deform the ID of that hole. We use the inside of the tail pull hole as the guide, then open up a bit more.
Mapleflt wrote:Pardon me, say again please !!!!
hotrod180 wrote:Installation tip-- hoist the tail up into level attituds. Much easier tk shinny backwards out the tailckne when youre not trying to go uphill at the same time.
bat443 wrote:My 73 185 had the factory installed tail cone handles, came out both sides. I installed the BAS handles in a 170B, used screws so that I could take the handle out if extensive work was ever need on the aft bulkhead.
