Backcountry Pilot • O-300 or O-360 (C170B)
46 postsPage 2 of 31, 2, 3
Re: O-300 or O-360 (C170B)
Scolopax wrote:If it’s within the realm of possibilities, an O-360 with an 83” MT prop will make about the best backcountry plane possible out of a nice 170B. If I didn’t take my family camping several times a year, I’d trade my skywagon in for a 180/170.
You can flight plan for 115 knots on 6 gph with that combo. With its light weight it will handle rough stuff better than a 180 and like all 170Bs, will land almost as short as most cubs. The difference is that with the 180hp Lyc, it will get out of that same short field.
Don’t know what it would cost to convert one, but I’m guessing 60-ish… Used to be you could get a mediocre 180 for the cost of converting a 170 to 180hp. I believe that has changed. All 180s are through the roof. I don’t think that converting a 170 is as much of a losing proposition as it once was.
Plus it has a nice round tail !!!! :wink:
Not sure I get 114 at 6gph. I have a Hartzell 78". I plan 105kn at 9gph.
This was level with maybe 25 kn push at 24 squared.so maybe 110kn.
I was seeing 120 mph @ 2400 on 10 gals/hr running a 84/42 FP prop @ +5C OAT.
daedaluscan wrote:Not sure I get 114 at 6gph. I have a Hartzell 78". I plan 105kn at 9gph.
Is that the Foreflight app ?
Yes, Foreflight. A bit $$ but it is amazing. Worth it for me. I love the weather, and in the USA that comes in on Stratus. In Canada by cell. Planning. CFS. Up to date charts. You can overlay ceiling, wind, radar, 100LL prices, visibilty (awesome when its smoky) AHRS, synthetic vision, profile….
I’ve heard of others using 9-10 gph. I’m basing my fuel estimates off of my Husky with an MT. It also has an O-360 Lycoming. After initially believing that I had made a mistake, I took a closer look and then again, and sure enough…after hundreds of hours in the plane, we actually average out under 6 gph at 112 knots in the 5000’-10000’ altitude levels. This is at 2350 rpm, 21 in MP, leaned about 50 ROP. Must be something wrong with my setup, but it runs nice and cool while burning surprisingly little fuel. I expect that the 170 is aerodynamically cleaner and would go faster than the Husky, but can’t be certain.
Scolopax offline
I’ve got a lot of time in both Huskys and 180 hp 170B. I can’t really explain why, but the Husky is quite a bit more efficient. If I ran the same very low power settings I used regularly in Huskys in the 170, I always got quite a bit slower speeds. And this was at “relatively” similar weights, so I always have assumed it was a drag issue.
I regularly ran Huskys at 6.5 to 7 gph, and airplane cruised just fine. But in the 170, to get similar speed, I needed between 8.7 and 9 gph.
Long ago, when I was a junior engineer at Aviat, Herb Anderson, the brains behind the Husky, told me about how he modified the Clark Y airfoil to lower the wing drag.
He must have made a pretty good decision there, because the cruising efficiency of the Husky is remarkable. I think that the design of the MT prop helps considerably to that end as well.
Scolopax offline
Agreed. That said, I used MT props on three Huskys and also my 180 hp 170.
Sell it for 40K. Take the 60K you will spend on the conversion. Add 20K. Buy a 180.
behindpropellers offline
Aircraft: C206 & Cub
You wrote "add 120k" wrong.
behindpropellers wrote:Sell it for 40K. Take the 60K you will spend on the conversion. Add 20K. Buy a 180.
soyAnarchisto wrote: wrong.
hahahahaha. Exactly what I thought when I read that post.
Good luck finding a decent 180 for $120k. Try $220 these days.
www.avthreads.com
I wouldn't sell my 170 for $120k
That's why I said that converting a 170 is less prohibitive now than it was ten or fifteen years ago, when the bottom end of the 180 market was 60k and the top was in the low 100k range. It's a tough time to be hunting for a wagon.
A nice 170B with an O-360 and a composite prop is an incredibly sweet ride! Especially with fuel going up the way it is.
Scolopax offline
"Especially with fuel going up the way it is."
I'm an optimist, the last time fuel prices soared, the average airplane owner nearly ceased flying in my part of the country. Airports became almost ghoast towns except for the affluent, who's pocket book is much larger than most. Airplane prices plummeted to almost giveaway prices and actually some planes you couldn't give away!! Lot of planes in the hangars didn't see daylight for a long time.
Me? I'm not affluent but will continue to fly just like I did the last time. I rode out the storm per se. Just a few less hours flown, but I stuck it out and happy I did.
Hopefully the high fuel prices will come down and we can all continue enjoying what we love doing....burning holes in the sky!
100LL has hit about $2.50 per liter in my area
Mapleflt wrote:100LL has hit about $2.50 per US gallon in my area
Serious?? That's cheap. It's $2.50 /liter in Alberta. $9.45/US gallon.
Typo sorry, per liter here as well. #-o
I would consider "halting" or reducing ski flying in favour of summer float flying if it ever came to that.
Almost had to think of moving per Ontario for a second. Haha.
Far to many lakes & trees around here for a western Flatlander. :wink:
