CParker wrote:Wanted to update this thread with the final results:
akaviator wrote:CParker wrote:Wanted to update this thread with the final results:
Man, that is PERFECT. I need to speak to an avionics shop and see what that would run me.
asa wrote:akaviator wrote:CParker wrote:Wanted to update this thread with the final results:
I have a feeling Cparker likes the round form of CGR, they do look clean.
CParker wrote:asa wrote:akaviator wrote:CParker wrote:Wanted to update this thread with the final results:
Guilty as charged, function is non-negotiable, but form is a very close second for me.
mtv wrote:On the AV-30C, I would strongly recommend adding Density Altitude information on one of them. Also, I'd install two of them, VFR or not. A DG is still a very useful tool in a VFR only airplane. I installed both AV-30s, and would do so again.
But, the Density Altitude display is an easy add on, you have to add a temperature sensor, that plugs into one of the AV-30s.
In back country flying, certainly in the mountain west, an instant readout of density altitude is a serious tool to have.
And, I'd reiterate that I'd go with a JPI EDM 900, which provides ALL required information on one page. Makes no sense to me to try to reduce instrument clutter, and use two holes for an instrument monitor, when one of those holes is really just there for a single additional indication.
CParker wrote:Carb temp is the only value I sometimes struggle with. Everything else is really nice. The reason I say I struggle with it is because it's not necessarily a serious issue in all operating conditions, but it will annunciate either way.
If carb temp goes into the yellow, you can completely silence the alarm. If the value goes into the red, the annunciator will stay red but stop flashing if you silence it. So, essentially it conditions me to accept an annunciator light. I don't really like that, but I don't necessarily want to pull that function from the annunciator either... not sure what to do with that.
This has encouraged me to run partial carb heat, even during high power cruise. That isn't necessarily a bad thing, but again just sort of a weird situation I need to figure out.
