Project: 180 Skywagon - The On-Going Saga
Wed Feb 27, 2013 10:56 am
The mats can come in all thicknesses... What I am using is super thin and light. I was a bit off with my "2" lb. I just looked up the weight of the floor I installed in the C170. It was 4.7lbs total. Still pretty damn light. Others may argue its not enough padding, but I found it fine. I will weigh the 180 mat when it goes in.
2358
- Aircraft: C180H / C170B
Wed Feb 27, 2013 11:10 am
Finally got the test panel from Avion today (that's a whole long story in itself ) Heading down to the hanger for a test fit. Goal was to have a nice simple panel. The MVP-50 (upper right) was able to eliminate tons of stuff so it will be very clean and light.
2358
Very cool. Looking forward to seeing it in the bird.
Now that I'm finally wrapping up my interior - my panel project starts next. I'll have just a few more holes then yours (like twice as many probably).
Barnstormer offline
2700
- Aircraft: C185
Wed Feb 27, 2013 11:45 pm
Bigrenna, thanks for the info on mats. I called Aerofloor and they said 9 lbs per square yard. Doesn't seem right either, seems like it would take a couple square yards to do a skywagon floor. Interesting you mention different thicknesses, they didn't mention. I'll have to ask them. What thickness did you use?
skyjeep offline
88
They sell four or five different products and some are quite thick. They do the material for the new Cessna floor. This has a thick closed cell foam backing that is nice and comfy and deadness sound, but is heavy. They also make some of the diamond plate style that others here have used. These too are very heavy. I will try to get my sample kit back and take some photos.
2358
Thu Feb 28, 2013 10:12 am
Fit the panel test blank yesterday. Needs a bit of trimming and slight changes, but we're on the right track...
2358
Thu Feb 28, 2013 10:15 am
The panel looks great Greg. Keep us updated on what you find out from Aerofloor.
2809
Thu Feb 28, 2013 11:15 am
This is what I am using. Its called "Aerofloor DOT" purchased from AIP Source.
http://www.aipsource.com/prodcat.aspx?Id=14&page=8024Super thin and light weight. Comes in different colors. I went with grey. Sells by the yard and is 54" wide which is plenty (skywagon cabin is about 38" wide at the floor.) I ordered 4 yards which will be enough.
Here are images of the load surface, back, and its thickness.
2358
Thu Feb 28, 2013 12:35 pm
delete...
Bigrenna on Thu Feb 28, 2013 7:43 pm, edited 1 time in total.
2358
Thanks for the Aerofloor pics, that's great. I didn't realize it has some kind of fabric backing vs. just rubber, I think I like that idea to let moisture breath out vs. getting trapped. I've got some samples of the "Loncoin" coming in, looks like that's what you have?
Nice looking panel layout BTW, that's what I'd like to do. My 55 has the smaller panel but I have seen layouts where this would work, although a little more cramped on the left.
skyjeep offline
88
Correction, looking at the website I do see "Aerofloor DOT" but doesn't look like it has the "coin" pattern you show on yours?
skyjeep offline
88
skyjeep wrote: I've got some samples of the "Loncoin" coming in, looks like that's what you have?
The Loncoin has much larger patterns. The dots on mine are only 3 or 4 mm in diameter. I also think Loncoin is way heavier.
The weight of AeroDOT is 30 oz per sq yard or 1.87lbs per sq yard.
2358
Thu Feb 28, 2013 11:08 pm
Thanks, that's much better on weight. Guess I'll get some new samples. Thanks for the help, hope to return the favor sometime but will be hard to get to something you haven't already done
skyjeep offline
88
Got my yokes back from the re-finisher... nice to see some stuff shaping up.
2358
Really good progress today... damn near almost ready for painting the interior. Prep prep prep prep...... So sick of anal prepping. But we are almost over the hump.
Pulled it out in the sun today and got a bunch of sanding done inside. Cant wait to start getting it back together.
2358
Keep up the good work!
3263
- Aircraft: 1957 C-180A
Wow. Stunning to see it without paint. Shiny!
Fantastic job you are doing.
Barnstormer offline
2700
- Aircraft: C185
Wed Mar 20, 2013 10:04 pm
bigrenna,
Who refinished your yokes? The project looks amazing.
Hang in there!
Brent
cowpilot offline
125
'49 170A. (his)
'56 172. (hers)
