Project: Cessna 170B BACK IN THE AIR!!!
shortfielder wrote:Tom Anderson is working on a Titanium .T/W spring for the 170, problem solved
Cool.
BTW, there's a 170 Belly Drain Kit on eBay right now. Nice addition if you've got things apart anyway.
-DP
2793
- Aircraft: C-170B+
Man, you really are determined to get the cost of that thing to $100 K.....
If it says titanium, bring $$$$. I know a guy who makes carbon fiber tail springs....incredibly light, but......
10588
I'm not interested, but Tom has been good to me, so I'm just putting it out there.
Gary
shortfielder offline
2345
- FindMeSpot URL: http://share.findmespot.com/shared/face ... D263l9HKFb
Looking good Rob!
But just a word of caution... it sure does come apart way faster than it goes back together. The deeper you get, the further you move away from summer flying. (Dont ask me how I know)
Regardless, its worth it in the end. You are going about it the right way indeed!
2358
- Aircraft: C180H / C170B
bigrenna wrote:Looking good Rob!
True statement, I may be renting to go to JC this year. I have access to a nice T-41.
3263
- Aircraft: 1957 C-180A
robw56 wrote:I have access to a nice T-41.
That's what I rent, but they won't let me go to grass or anything other than paved. I've begged and begged, and worked for them, no luck....just pavement.
1736
Fri Jan 03, 2014 10:04 pm
Nothing against unpaved surfaces for this one, just has to be at least 2000x50.
3263
I finished stripping the rest of the belly today... what a pain in the ass! At this point the fuselage is about 99% stripped, there's just a few areas left that need to be cleaned up.
3263
Looks great Rob. I'm following closely as my '56 172 is quite similar. Two years ago, I pulled all the antiquated narco junk out of mine, i put everything in a box and it weighed 42 lbs! I replaced the 42 lbs with a garmin audio panel. The adf cable alone weighed 13lbs! Good luck! Keep the pics coming.
Jeredp offline
625
- FindMeSpot URL: http://share.findmespot.com/shared/face ... 7NYN40QT2I
- Aircraft: Cessna 172
Rob,
Good to see your machine has the access port for a fuel selector quick drain....that drain can save you a lot of grief.
10588
Awesome job keep it up! stripping is the worst the other stuff is where the fun starts…
18043A offline
23
UPS delivered a bunch of goodies from Selkirk and Great Lakes Aero today! I weighed the 1/4" Selkirk foam and a 20'x55" roll weighs 7.6lbs, not bad.
3263
Thu Jan 09, 2014 12:04 am
Rob when you go to start making a new panel make your template out of lexan it is way easier when you can see through it as oposed to something opaque like cardboard or plastic. Plus you can trace your instruments on it with a dry erase marker to see if they clear all the brackets before you start cutting.
River rat offline
749
ccurrie wrote:Rob when you go to start making a new panel make your template out of lexan it is way easier when you can see through it as oposed to something opaque like cardboard or plastic. Plus you can trace your instruments on it with a dry erase marker to see if they clear all the brackets before you start cutting.
What a great idea!!
Mark J
marcusofcotton offline
259
Great idea for sure, I like it!
3263
And make me a new panel too, as long as you're making panels and stuff...
Seriously, this is getting contagious. It's taking all the restraint I have to not rip my plane apart.
amacbean offline
544
- FindMeSpot URL: http://share.findmespot.com/shared/face ... 7GsCKYBvNX
- Aircraft: Cessna 170b
You'll love the stripping part that's my favorite.
richw56 offline
124
- Aircraft: Cessna 120 125 Lyc.
I was down last week helping Rob
On his 170. as it turned out when we were pounding rivets we counted about a 100 of them not 60. We hadn't done any riveting together in over 10 years and we fell right back into it just like it was yesterday. It was a lot of fun.
richw56 offline
124
