Backcountry Pilot • Project. Straight tail 182. Pponk
101 posts • Page 5 of 6 • 1, 2, 3, 4, 5, 6
Re: Project. Straight tail 182. Pponk
Denali Bandag used to buff those 29s down for us to remove the tread, and lighten them up some. Made them better tires in my opinion.
Your project looks great.....you've obviously kept your priorities in order, and the result is a good functional airplane.
PAMR MX wrote:Finally got some bigger tires...
8.50 on heavy bush wheels aluminum wheels.
Do you happen to know the weight difference between the 6" Cleveland wheels and the 6" ABW replacements?
Not sure on the weight difference. Tried to weigh a few 8.50 tires mounted on Cleveland wheels but I got a few pounds of variation between the setups. Maybe a pound per wheel? Total guess.
PAMR MX offline
My elevator trim pretty well froze up as soon as the cold weather got here. I had some repairs to the tail I wanted to do so took all that stuff apart and will be going through it over the winter.
The rudder was first on the list. The upper portion of the rudder was bent up. The skins get dented around the balance portion of the rudder. I think it's all from wind damage. Some cruel individual re skinned one side with ALL cherry max except the trailing edge. Skins all drilled off.
I have seen these rudder tail posts with significant corrosion. The steel also tends to corrode out the surrounding aluminum parts. This issue is an AD on a few types of airplanes. This one wasn't that bad.
All the parts cleaned and ready for paint.
Epoxy prime complete. I like to use the Poly Fiber epoxy primer.
I like the skins made my Air Metal Fabricators in Washington. They need to be cut to size but they are significantly cheaper then Anything else.
The frame is really fun to put together. It's really had to screw up since you have access to everything at this point.
And just like that out of the jig and done!! It's really that easy. Lol.
Next the horizontal stab if people are interested at all.
PAMR MX offline
cool, thanks for posting.
Any pics of the jig, or what you did to make the jig?
Look forward to following along.
jake
Slantbuggy offline
PAMR MX wrote:My elevator trim pretty well froze up as soon as the cold weather got here. I had some repairs to the tail I wanted to do so took all that stuff apart and will be going through it over the winter.
Really like your craftsmanship and attention to detail. Keep sending more details .Thanks
182 STOL driver offline
Finished product looks great! But what jig? Looks like everything was just laying on a plywood table.
So is skin from Air Metal Fabricators cheaper than from Karl Anderson?
He lives near Skagit airport in western WA, I've been to his shop and he does beautiful work.
Yes, keep the pic's coming.
Thanks for the good words.
I will check with Anderson and see what his prices are. Funny that there are two people in Washington making corrugated skins. I know air metal has an stc with their skins.... Not that I think it's required. They also make the trailing edge flap bulb.
I didn't get any pictures in the jig... Even if you used all the original parts it would not be very straight if ya just did it on a plywood table with no jig....
Horizontal wasn't too bad. It had some minor dings and bent cracked ribs.
Skin removed down the the ribs.
The whole thing fits on one shelf.
I should have parts cleaned and all the new parts next week to finish.
PAMR MX offline
pretty cool to see the work that you are doing along the way, particularly on the skins.
keep up the documentation of the thread. it has been very informative.
that thing must be a real rocket ship!
Mojave Flyer offline
Aircraft: Piper PA-28-180
This is really cool. Thanks for the post PAMRMX.
Very cool please keep posting.
bushpilot490 offline
Aircraft: C-175 with 180hp conversion
Good morning PARM MX. When you get a chance would you mind posting a photo of your rudder jig. In a couple of months I will need to replace the skins on the rudder of my 180 project (actually a 185 rudder for the gross weight increase STC) and it would be nice to have a place to start when building a jib. Does your jig support the trailing edge of the rudder or just the hinge line? Thank you.
bat443 offline
Made some more progress on the stab today. One IB rib was bent with some cracks, one middle rib was squashed and all the nose ribs were old style ribs. It also had aluminum aft stab brackets one of witch had the typical crack. Cessna has really been jacking up their prices on this stuff. $1500 just for these few parts.
The new nose ribs are one gauge thicker. They also have the flutes a bit smaller and allow for more rivets helping to alleviate cracking.
The new rear stab mount brackets are steel rather then aluminum. Much less prone to crack.
Etch and alodine all parts. A tote works great for alodine soaking the smaller parts. 1 to three minutes is all you need.
All epoxy primed. It should last a long time.
Pretty much every tinnerman nut plate was busted. Thought it be cool to install machine screw nut plates but decided to stick with sheet metal screws. 24 of them on here.
The best sheet metal air drill in the world. Sioux. Love this little guy.
All the new skins get dimpled where the nut plates live.
PAMR MX offline
Cool, please keep posting!!! Very interesting.
Very nice, love to see the work. I had my '55 C 180 wings re skinned(severe corrosion) in 1991 by a repair station. I remember when checking with the owner and he told me he could get everything he needed from Cessna. I was surprised that they still supported such an old airplane and that was 1991. He even bought flat skins which were expensive. I thought he would make the easy skins but 12 grand later I had my wings. For many years my dad had a '56 tall gear C182, I got my instrument rating in it. It was a hell of an airplane. I would buy it back if I could but it shows destroyed on the registry. I bought one of those Sioux drills about ten years ago, expensive but I've never been sorry. Works perfect.
Kevin offline
You're doing a great job, keep the updates coming!
The day I picked up the 182.
Today
Stripping paint is a monumental project. It may be the least fun thing a person can do with an airplane.
Polishing aluminum isn't exactly easy either but at least it looks cool! Still have lots to do but mostly just flying this summer.
PAMR MX offline
Looking awesome!
I've really enjoyed your updates and the polished aluminum looks great!
EDW offline
FindMeSpot URL: https://share.delorme.com/EricWieman
Aircraft: Cessna 172
