whee wrote:Took the engine to a friends shop where he has a flat bed scale. Placed the engine as pictured on it including the pallet and a few feet of chain. Total weight was 452lbs. Figure the pallet weighs 30lbs and there is at least a couple lbs of chain there so 420lbs for the FWF minus prop.
whee wrote:That's exactly what is going through my head. I've had the experience of engine trouble while flying over terrain with my family aboard.
whee wrote: I might as well go with the big bearing case and get a big bearing crank.
whee wrote: I really wanted a 220 Franklin to put in my BH but mogas is a must for me......
whee wrote:The case has to be bored to fit the the big bearing crank. Aircraft specialties can take care of the machine work. New rods are required too.
Reman cranks have proven impossible to find. A new crank from TCM is $6600.
pilot wrote:Whee, in your research did you look at the io-360 DB? I was wondering what if anything may make it better/worse than a straight io-360-D model?
maules.com wrote:Whee, I don't think the IO360 Continental can use autogas. Not at 210hp as we have it on the Maule anyway. The Franklin O350 at 220hp can't run autogas either but will out perform the IO360 and is lighter weight.
Maybe it can at 195hp as on the C172 ?
whee wrote:Made some calls yesterday and talked to Petersen Aviation.Great guy that spent some time talking about engines and mogas with me. He said they had all kinds of vapor lock issues on Lyc fuel injected (bendix) engines running mogas but the TCM fuel injected engines didn't have any vapor lock issues at all. The FAA wanted a boost pump on the TCM engine just to be safe so they installed a electric pump that provides ~4psi of extra pressure at the fuel tank. This was on the IO-520 and IO-470 engines.
They guy I spoke with at Fly Inpulse said they have seen some ticking of the fuel pressure gauge on their Cessna 180 (can't remember if it is a IO-550 or 520) when they turn the boost pump off at high altitudes on a hot day. He said that indicates vapor in the lines and it goes away right after they turn the boost pump back on.
I looked at the schematics of the FI systems for the IO-360 and the IO-470 in the overhaul manuals. They look very similar if not the same; even the description is the same. The IO-470 that is approved on the Fly Inpulse STC is the 8.6:1 compression version.
So with all this info it seems to me that a home builder should be able to successfully run a TCM IO-360 on mogas if they wanted to. I'm not sure that the water/methanol injection system would even be required.
whee wrote:For you old timers with short memories[emoji6]whee wrote:......So with all this info it seems to me that a home builder should be able to successfully run a TCM IO-360 on mogas if they wanted to. I'm not sure that the water/methanol injection system would even be required.
whee wrote:Took the engine to a friends shop where he has a flat bed scale. Placed the engine as pictured on it including the pallet and a few feet of chain. Total weight was 452lbs. Figure the pallet weighs 30lbs and there is at least a couple lbs of chain there so 420lbs for the FWF minus prop.Untitled by Jon Whee, on Flickr
Untitled by Jon Whee, on FlickrUsers browsing this forum: No registered users and 9 guests
