Zzz wrote:whee wrote:I felt that the 180hp lyc O360 was sufficient for me in a Bearhawk and I don't want the extra weight of a 540.
I struggle with the same question. The 540 is pretty popular on the Bearhawk, but definitely some extra pounds there. The reality though, is, you have 2 kidsYour performance is going to dwindle year after year as they grow. The fuel savings isn't much, especially with injected, but the empty weight when solo (and doing fun things) won;t be as favorable.
I fly an O-360 172 right now, 2 of them actually. 1450 lbs vs 1520 lbs. I need more power. I used to fly a Hawk XP occasionally, too. That was a great motor, the IO-360 Continental, at least for the few hours I flew it. Definitely a little snappier, but I think the magic starts to happen around 220hp. The IO-390 is tempting, or rather, the XP-400.
mtv wrote:I haven't flown a Bearhawk, but judging from the all up weight, you're going to want some horsepower. Again, you can get some power out of an IO 390 at 210 hp or so, but at that hp, a 540 will cost half as much or less and be loafing along.
Zzz wrote:I do need an old IO-540. Get down there and find me a cherry!
Zzz wrote:Moist tropical environment + neglect = corroded to all hell most likely....
iceman wrote:just a word about mo gas since it gets discussed here for the IO 360.... not approved for the IO 360..if it was I would have gotten the stc long ago... and if you go to the back country. make sure you have a fairly new battery... I don't go to the back country without a fairly new battery...no problems... starts every time....hot starts have never been a problem anywhere at any altitude...I also have a lightweight starter that spins it over quite well, better in fact than the original... so make your own decisions on the IO 360 but I love mine....one other suggestion for an upgrade might be Gami Injectors... but then that's another discussion....
whee wrote:Is the IO360 engine mount and the O-470 mount at all similar? Avipro makes a O470 mount for the bearhawk and I'm wondering if it would be of any use to buy that mount and modify it to work with the IO360.
This is all just curiosity as I have bought a BH kit or anything yet.
m_moyle wrote:You'll need to build a bed mount for the IO360. To bad there isn't a dynafocal mount for the IO360's. I bought one of Avipro's O470 mounts hoping it would fit my IO520. Came close but the bed mounts were at a different angle. There is a Bearhawk in Brazil flying with the IO360.
River rat wrote:I've heard that a cessna 337 rear engine mount bolts right up to a cessna 170, not a bearhawk I understand but it might be a good place to start. Hey it's experimental, get the saws all!
