Here's a little story to emphasize Kurt's recommendation not to use the numbers for practicing short field landings. I have the classified and illegally obtained series of pictures to prove the story, tucked away in a box. A friend of my Daddy was in the tower and took the pictures for official purposes, but then made copies as a "favor".
My Daddy was training in B-25s at La Junta, CO, in 1944. La Junta was one of those sleepy little towns that became a major training base, and the Army created the traditional triangle shaped airfield with extremely long runways. Today, one of them has been closed, and the other two have been shortened, but they're still pretty lengthy. But of course, the young pilots had to learn what we call short field landings, and what the Army Air Corps called "assault landings". I guess from my observations when I was learning to fly at Elmendorf AFB back in 1972-3, that's still the military jargon.
So on the day of this event, my Daddy was assigned as the aircraft commander. Always the show-off, he decided that he'd make the shortest landing of the day. Problem: he landed a few feet before the runway, the mains caught the lip of the concrete and were ripped off, and the airplane skidded down the runway, making 2 complete rotations before coming to a stop. Fortunately, no one was hurt. Whether the airplane was fixed, I don't know, although the damage was extensive from what I could see in the pictures (it's been at least 10 years since I last looked at them). Ultimately, he was cleared by the Review Board and returned to flight status--the contractor was blamed for failing to infill the areas at either end of any of the runways per the contract, which left an approximate 7" lip on all of them.
Because of subsidence of the turf at the edges of runways, you could run into the same problem if you land short at many paved airports. If you're relying on power to make sure that doesn't happen, remember that engines quit now and again. Many of us here have had engines fail completely--not fun! But even a hiccup when applying throttle as you realize you're not going to quite make it can be disastrous.
And that happens. I had the engine stop on short final to Merrill Field's 34 in a 150 when I was a student pilot in January 1973. I had forgotten to add carb heat, and when I thought I needed a little power to make the field, instead of responding, the engine just stopped altogether. Fortunately I was wrong--I didn't need power to make it, and I landed. But it was a typically busy day, and several airplanes had to go around because I hadn't been able to coast off the runway at the nearest taxiway, and it took me a few minutes to move the airplane by hand. So I had the ignominious "pleasure" of clogging up the airport for a time--not my proudest student pilot moment.
So it's much better to choose a spot that is farther down the runway as your touchdown spot. The thousand foot markers on an instrument runway are good. Sometimes there will be something to the side of the runway, like a bush or a light or somesuch, that you can use as a reference.
The only other piece of advice that I would offer that hasn't already been offered is don't rely on your brakes any more than necessary. I've watched a couple airplanes nose over at OSH, when the pilots were trying to show off their short field prowess, and there are all sorts of videos on YouTube that show that, too. There are, of course, pilots who have the incredible skill to feel the airplane begin to nose over at just the right split second that they can release the brakes in time, but don't count on developing that skill for awhile--and sometimes developing that skill seems to mean dinging an airplane or two in the process.
. I have not been able to fly the double slotted flaps yet but in a stock super cub, or pacer you can get that nose high enough on approach that you really can't see the touchdown or flare. In the pacer a steep approach with full flaps and slip allowed me a much better view of the runway, people, planes, or critters trying to come under me. I will occasionally slip the cub a bit for a better view or if too high, With crosswinds I never crab the cub/Cessna I do a forward slip all the way to landing that gives me a better ideal of what I have to deal with once I am on the ground, the wind is usually a bit less so if I can hold it on approach I should be able to hold it on the ground. In a light cub or cessna you don't have a lot of time to get both wheels on the ground so you can brake before the wind overcomes the forward motion of the plane and starts to overpower the tail. If I can't hold it on approach best to go somewhere else or land in another direction. Most are trained to crab and kick to forward slip at touchdown so many disagree with my technique. I have stalled a great lakes in a hard forward slip with extreme nose up. It was a non event high wing dropped level and then it went back into a slip. I plan to try it with the cub after the skis are off.
