piperpainter wrote:And I went ahead and posted a response....that forum should get good!!!
http://forums.aopa.org/showthread.php?t=94023&page=4
You should be able to read, just not post, at the AOPA forum, without joining.ExperimentalAviator wrote:piperpainter wrote:And I went ahead and posted a response....that forum should get good!!!
What did you post? I don't have a AOPA acount so can't view the forum.
I hadn't noticed the leaves. Good point. A downwind take off, while certainly doable under proper conditions, isn't a good idea on a relatively short strip. Even the lower powered Bonanzas would have no problem in a no wind or headwind situation on that strip--contrary to the way some folks fly them, they're not really fighter plane wannabees, no more than a Mooney is. They're very capable airplanes, flown properly.TomD wrote:I have been into Mears aka Concrete a lot, normally land on the grass strip to the North of the runway; however, when I can see the bottom of the leaves of the trees and see them waving in the wind like you see in this video, Eastbound departure is wise.
Concrete sits at the bottom of the Skagit river valley and there is a serious venturi effect.....sound familiar folks?
My Maule would probably not have had that much of an issue, after all as mentioned the field altitude is all of 267 feet. Even with the heat the DA probably was not much above what field elevation would be in the Idaho or Utah back country; however, if I am getting a 25mph takeoff speed gift from the wind if I go East with no obstructions would I not be a fool not to take advantage of it?
I have never flown a Bonanza but watching them depart my home airport tells me they don't "jump" into the air. They are fast once up there. Knowing that why take off downwind?
Last summer the winds were 26 mph right down the runway at the end of the annual fly-in with everyone departing into the wind and some "experienced" SeeBee pilot landed straight in downwind into traffic. More "questionable" decisions.
Be safe out there.
TD
Cary wrote:You should be able to read, just not post, at the AOPA forum, without joining.ExperimentalAviator wrote:piperpainter wrote:And I went ahead and posted a response....that forum should get good!!!
A1Skinner wrote:I get the same EA. Can't read them if I'm not a member. I'd really like to read the comments, even though I'm pretty sure they'd be making my blood boil.
richpiney wrote:Here is what I have to say to them:
"Your Red Bull Gives Me Wings!"
Backcountry Pilot is awesome. What is means is: Hey fellow Pilot, We have your back!
I can't thank you guys enough for standing up for me and the Flying Hawkes.
Richard
