Hi Hotrod,
I'd agree, but this gentleman had a question. I think it's a good one, and while I'm certainly not in the position to provide instruction, I certainly don't mind sharing
my take on flaps
Lucky wrote:Hey everyone,
I have a couple hundred hours in a 68 182. I typically do 10 deg abeam the numbers, 20 after turning base and 40 half way down +/- on final. When are you guys typically putting in the full flaps?
Thanks
For a guy with a couple hundred hours in type, presumably in the city, you're doing as expected... and that's, not a terrible thing. In that environment the goal is to be safe, and predictable for controllers and other pilots alike.
The goal for fun, and
safer flying (in any environment) is to learn your wing. It will tell you what it wants, and that is all that matters. Outside of an 'airport' setting you may elect for any of number of reasons to fly a non standard pattern, and of course there is not likely to be any 'numbers'. Arbitrarily assigning 'locations' to lower flaps, will not help you in those settings. In fact in your airport environment it is not a great practice, it's just a 'get you buy while you learn' practice.
Manual flaps, or even electric or hydraulic flaps that don't have detents for fixed locations are infinitely adjustable, and consequently fit a wider variety of situations easier, but even with fixed flap settings you are still flying a machine in three dimension with variable speeds, so the combinations are only limited by mechanical limitations, safety, and what the wing wants...
Lastly, on most airplanes flaps are pretty easy to 'overspeed'. On some over built examples this simply leads to inefficient flying, but on our wonderful light examples it leads to damage. On 182's that damage typically manifests itself in convcaved lower flap skin surfaces, and beat up wore out flap tracks. If you want to be kinder to your airplane, learn to use your flaps such that they feel like they are just another trim wheel. Slow the airplane down to the point that it
wants you to add flaps to fly the same as it just was... If you are using flaps to slow down, rather than to help you maintain a desired flight profile
after you've slowed down, you are adding them in too hot. In other words, don't use the flaps to change the way your airplane is flying, use them to keep flying the way it was for as long as you can. Done like this you will learn to slow it down and be kinder to the system, and you will arrive at full flaps each and every time, because you have ran out of trim... (flaps) to add. And for the sake of those that do not land with full flaps, I will add the caveat that you will land as close to full flaps as your comfort level allows
Take care, Rob
PS, somewhere above I said flaps are good.... that is only true until you break them or burn out a flap motor ..... So be kind to them!
