Backcountry Pilot • Spins
Spins
29 postsPage 2 of 21, 2
Re: Spins
Cary wrote:....any airplane which was authorized for spins that has an Avcon conversion loses its authorization, because the folks in Kansas didn't go through the necessary STC testing process.....
A guy I used to know bought a C150 Aerobat with an Avcon 150hp conversion. It either wasn't placarded properly, or (more likely) he didn't pay close enough attention, but after he bought it he griped about it no longer being aerobatic. Other than "intentional spins prohibited", it was still approved for for all the maneuvers listed in the POH so I didn't see the problem. But thinking about it now, perhaps the empty weight went up enough and/or the CG shifted enough to take it out of the utility category and into normal?
Re: Spins
I can't think of many people I know, other than the CFI I fly with, that would want to ride along for spins - parachute or not.
fshaw offline
Re: Spins
mtv wrote:Another point which hasn't been made here yet: You folks who claim you are regularly spinning your aircraft are wearing approved parachutes while doing so, and doing so with a certified flight instructor on board, correct?
Please reference 91.307:
(c) Unless each occupant of the aircraft is wearing an approved parachute, no pilot of a civil aircraft carrying any person (other than a crewmember) may execute any intentional maneuver that exceeds—
(1) A bank of 60 degrees relative to the horizon; or
(2) A nose-up or nose-down attitude of 30 degrees relative to the horizon.
(d) Paragraph (c) of this section does not apply to—
(1) Flight tests for pilot certification or rating; or
(2) Spins and other flight maneuvers required by the regulations for any certificate or rating when given by—
(i) A certificated flight instructor
In other words, the ONLY time you can practice spins legally without a parachute is when you are engaged in the training required for the CFI, and a CFI must be aboard for that training to be legal, or during a flight test, and to the best of my knowledge, the only flight test which requires spins is the initial CFI.
Any time I have done spins without parachutes with someone, I have been careful to log the flight in their and my logbooks as flight training toward the spin training requirement of the Flight Instructor certificate. Note that you can do so with a Private Pilot holder. They don't have to be actively pursuing a CFI at the time. You're just prepping them for that training.
Be careful out there folks.....there are lots of ways to get in trouble with spins.....know what you're doing before you go there or allow someone to talk you into doing so.
FWIW
A rather peculiar interpretation by the Chief Counsel's office indicates that even if the student has no plans to ever become a CFI, that quoted reg's words "any certificate or rating" allows spins without a parachute by any "student" seeking any new certificate or rating as long as the CFI is providing instruction. The interpretation also makes it clear that solo spins are allowed without a parachute; but spinning while having non-crew member passengers aboard isn't allowed, period--no exceptions if the passenger is wearing a chute.
And as Mike says, that's why aerobatic airplanes with doors have quick release systems, such as the Decathlon which has a lever that pulls the hinge pins out with one pull of the lever. Ever try to open a Cessna's door in flight? If you can get it open more than 4 or 5 inches, you're a better man than I am, Gunga Din.
Re: Spins
Cary wrote:The interpretation also makes it clear that solo spins are allowed without a parachute; but spinning while having non-crew member passengers aboard isn't allowed, period--no exceptions if the passenger is wearing a chute.
"period--no exceptions if the passenger is wearing a chute."
uh, wut?
Bagarre offline
Re: Spins
There is no placard requirement; it's in the STC. I hadn't bothered to look at the STC, but my IA pointed it out to me. So I added a "spins prohibited" placard to mine, just to make it clear in case I were to lend my airplane to a friend, since otherwise all 172s are authorized to be spun in the utility category.
I don't know whether the 150hp STC for the Aerobat affected the category (might have, I just don't know), but personally, I'd have been hesitant to do other permitted aerobatic maneuvers--it's too easy to screw up an aerobatic maneuver and have it fall into a spin, and adding a bunch of weight and moment to the front of the airplane could adversely affect other maneuvers as well.
I know that there are pilots who do aerobatics in non-aerobatic airplanes. Although most aerobatic maneuvers performed properly don't put excessive stress on the airframes, it's the screwed up maneuvers which can do that. To me, it's the epitome of stupid pilot tricks, to do prohibited aerobatics in a non-aerobatic airplane--or for that matter, to do aerobatics at all without proper training.
I'm just a tad sensitive about this issue, of proper training for aerobatics. Here's the story:
My Daddy died when the P-51 he was flying fell out of the top of a victory roll, because he hadn't had proper aerobatic training yet. He had been a heavy twin driver (B-25s and C-47s) in WWII and joined the Wyoming Air Guard after the war. The Army Air Corps was unloading a flock of P-51s on the Guard units all across the country, and of course, all of the kids in the Guard at that time wanted to fly them. All that was required to transition was 4 hours in an AT-6, and then several hours in the P-51.
His first hour in the P-51 was just in the pattern, doing take-offs and landings. The second hour was to introduce high speed flight, so he and his instructor (in another airplane--they were all single seaters) headed east from Cheyenne, climbed only to 12,000' MSL, and flew around for awhile, so that he could get used to the high stick forces involved at 400 mph. Then they headed back, and his instructor told him to follow him through with a victory roll. Like any good student, and with the military background, he did what he was told, but he stalled it in the process at the top of the roll. The airplane fell into a spin. Witnesses in another flight observed that he made a valiant effort to stop the spin, and that he'd succeeded in stopping the rotation but plowed into the ground, because there wasn't time to pull out.
Here's the issue: a P-51 loses altitude at the rate of about 2500' per rotation in a spin and takes about 2 1/2 turns to stop rotation with full anti-spin control input. Simple math: the rotation takes about 6250' to stop. They were flying at 12,000' MSL, which in that part of Wyoming (near Hillsdale) is only 6300' AGL.
If you're going to spin an airplane, get good instruction, do it from a sufficiently high altitude, and realize that if you don't recover it properly in time, you can die.
Re: Spins
My old POI has the only wing walking school in the states. He wears a chute, but since the wing walker gets out of the plane they don't have to wear one even during loops and rolls and such.
The beaver us placarded against spins....harumph!
Headoutdaplane offline
www.belugaair.com
Re: Spins
Seems like when many find there plane isn't certified for spins it's more like "whew"!
fshaw offline
Re: Spins
Headoutdaplane wrote:My old POI has the only wing walking school in the states....
Is that Mike Mason in Sequim WA?
http://www.westcoastspindoctors.com/index.html
Re: Spins
fshaw wrote:Seems like when many find there plane isn't certified for spins it's more like "whew"!
Reminds me of a story. My advanced student working on his IR asked if I'd follow him up to Casper so that he could drop his airplane off for some maintenance. His was a PA32-260, not approved for spins. I could, and we agreed that on the way back in the 172, I'd give him some spin training. Only hitch: the 172 had to be back by 7 p.m. for another renter.
We left Casper with plenty of time to do the spin training and still get back to Laramie before 7 p.m. But at some point, I noticed that we were chugging along at only about 1800 rpm, doing about 80 knots. I asked him "why are you flying so slowly?". He somewhat sheepishly admitted that he thought if the trip home was taking too long, there wouldn't be time to do the spin training.
After suitably chastising him for being such a wimp (we were friends, too, so the relationship allowed that sort of thing), we got off the airway, and I described exactly what a spin is, what causes it, that it's a relatively benign maneuver, how to get out of it, etc. Then I showed one to him, describing exactly what I was doing as I did it. Two turns later, I pulled it out of the dive, started the climb back to altitude, and asked him what he thought of it. "That wasn't nearly as bad as I thought it would be."
"OK, your turn. I'll talk you through it, but I won't touch it." He did just fine--he was a good student anyway, so for the first one, saying to him, "power off", he immediately pulled the power; "opposite rudder till the rotation stops, then neutral rudder", he "smartly" pushed the opposite rudder pedal to the floor, and as soon as the rotation stopped, he neutralized the rudder; "now forward on the yoke to break the stall", he pushed the yoke to about halfway, the wing unstalled; "now gently pull us out of the dive".
So we did a series of spins, maybe 2 or 3 each direction, and by the time we were done, it was time to head on to Laramie--and he was pretty happy that now he had not only experienced spins, but most importantly, he was no longer afraid of them.
