robw56 wrote:I like getting the tail up on takeoff as soon as possible for better visibility and to protect the tailwheel on rough ground, I don't think using brakes is the best idea though. Just start your roll with down elevator like others have said.
svanarts wrote:robw56 wrote:I like getting the tail up as soon as possible. Just start like others have said.
FWIW, this is what I do too.
M6RV6 wrote:svanarts wrote:robw56 wrote:I like getting the tail up as soon as possible. Just start like others have said.
Me too, I just can't as often or as hi as I used to?
:) any day I can get my tail up is a good one!
Jeredp wrote:FWIW, this is what I do too.Me too, I just can't as often or as hi as I used to?:) any day I can get my tail up is a good one!
At 29, I can't hardly keep mine down
hmmm.... Risk the tail wheel.... Vs risk the pponk ....clippwagon wrote:My opinion about the technique in question is that there is value in knowing how to do it and when to do it but it may not be beneficial to over utilize it for many of the reasons stated above. It's kind of like some pilots views on practicing (or doing) power off landings. Those that adamantly oppose them have their reasons but when I actually needed the technique for real it was a non-issue because I knew what to expect. I had practiced it...a lot!
CW
Heck even an idea of how to determine when a prop is actually most effectively working.
) Not a big gain by holding the brakes and powering up(which again doesn't seem like a good idea in the dirt, can we all agree on that?
)In the PAST I would taxi around with my tail up all the time for the practice. Bet I have over a 100 hours with my tail up in the air taxing around at a very slow speeds. Slower you go the more challenging it is. I would even set up cones to do this until one day... the pretty little bird looked more like a wind sock as it stood on her nose...
There is no need to do this. As Rob and others have mentioned, get your tail in the air as soon as possible / until you have elevator effectiveness...
Zzz wrote:The beauty of the tailwheel design for bush flying is that it allows you to keep the propeller higher up out of rocks and debris when you mash the power from a standstill. Should you mash the power in rocks or gravel? That's debatable, but the tailwheel design has the advantage of keeping that prop "cone of suck" a little higher up.
dogpilot wrote:Props are expensive as noted. Then as an A&P I feel you should wear it out quickly, kids are done with college and now all the spare money goes towards toys, god knows I need toys. The rule of thumb I always taught in Africa was get to a walking pace then full power. It saved tens of thousands of dollars on props. We also took old oil from changes with use to pour over the spots we ran up on the end of the runway, this along with sweeping the area with a broom, worked well. Yes I know, not very environmentally sacred. Then again, the mortars and artillery shells seem to have a greater environmental impact. Beside the minister of the environment and singing birds in Somalia seemed to be really busy on other stuff.
I try to get my tail wheel up quickly as well, but when I'm at above a jogging pace, unless the heads (rocks) are as big as Putin's Head
Scale of rocks: pin head, government worker head, baby head, typical head, hydrocephalic head, rock star head, Vladimir Putin's head
