Backcountry Pilot • Tail Up Takeoff
Tail Up Takeoff
46 posts • Page 3 of 3 • 1, 2, 3
Re: Tail Up Takeoff
Personally my hat size varies from pin to hydrocephalic, depending on the angle you view me from.
dogpilot offline
Took ball and went home
Re: Tail Up Takeoff
Noticeable acceleration occurs when:
1. the nose or tail wheel is off the surface,
2. the mains are off the surface,
3. and the nose is pushed down to remain in low ground effect.
Big rocks, brakes, mud, high grass, tie downs, and drag chutes are serious limitations to acceleration, which is necessary for takeoff.
We want to go fast on takeoff and slow on landing.
Re: Tail Up Takeoff
contactflying wrote:Noticeable acceleration occurs when:
Contact, How did I do on this one?
Did not seem to want to work so here this is
https://www.youtube.com/watch?v=9aey3LzILnk&feature=youtu.be
M6RV6 offline
Re: Tail Up Takeoff
Gotta love that sound... :-)
Coyote Ugly offline
Track My Spot
Re: Tail Up Takeoff
M6RV6-That was a good one. If you can get the mains off sooner and then level in low ground effect, it helps. You are a bit tight there. Do what is comfortable. Is that engine a "shakin Jake?"
Re: Tail Up Takeoff
contactflying wrote:M6RV6-That was a good one. If you can get the mains off sooner and then level in low ground effect, it helps. You are a bit tight there. Do what is comfortable. Is that engine a "shakin Jake?"
It just looks tight, had plenty of room to just climb out straight, but houses and trees straight ahead, big gap in the trees off to the right and that was the way I was headed. About 20 kts. above stall when made the turn, 985 P/W, Used standard TO position on the flaps (15), not soft or rough field position.
Just a bit downwind as the guy to the north does not like airplane noise and this thing makes lots of it!! :mrgreen:
Thanks
M6RV6 offline
