hotrod150 wrote:...Pacers have a bad rep but I have a little Pacer time & while quick handling you don't have to be superman to stay on top of them. I'm guessing that a Maule is probably pretty similar.
cropduster13 wrote:WHAT!! I have a M-5 and i'm pretty sure you have to be superman to fly it!!
OregonMaule wrote:Battson wrote:Sorry about thread creep.... but this has me interested.
Can anyone concisely explain why Maules are such a handfull on landing, esp. wheelies?
Is it simply the short fuse / lack of rudder surface combo?
Or something 'more complicated', like the distance between the centre of gravity and the mains?
pilot not the plane
g'day
rjb wrote:The 105 knots is indicated.
I went back and looked at my instrument flying cheat sheet and enroute cruise is
enroute cruise: 125 mph, 2450 rpm, 25 mp, 0 attitude indicator, 1st notch flaps - 0
which is actually 109 knots. I think I was probably around 3000 feet when I was constructing my cheat sheet which would give a TAS of about 116 knots.
enewmen wrote:….I estimate it's possible for an MX7 to get 125kts true at full-throttle IF flying at 10,000+ feet. At that altitude, the o-360 engine won't have engine detonation even at peak EGT. This way oversquare I'll get maximum TAS and highest MPG, ….
hotrod180 wrote:enewmen wrote:….I estimate it's possible for an MX7 to get 125kts true at full-throttle IF flying at 10,000+ feet. At that altitude, the o-360 engine won't have engine detonation even at peak EGT. This way oversquare I'll get maximum TAS and highest MPG, ….
I don't think you'll be able to run "oversquare" at that altitude unless your rpm's are pretty low.
Or you have a turbo.
andy wrote: A metal skin Cessna can be sandblasted and repainted for a lot less.
