Backcountry Pilot • Tri-pacer vs. tri-Maule??
82 postsPage 1 of 51, 2, 3, 4, 5
Still on the quest for my next bird and have come down mostly to the pacer. Only reason I hesitate is their price...can I really get a good shape 4-plane plane for under $30k? I’m only considering the 160HP tri-pacer.
my budget is $75k but it just seems that I should be able to find some more performance at $50k-$75k. Something in my brain is having me question if I can really meet my mission for less than half of my budget.
The C172/182 are out. I just remembered that Maule makes a tri gear and was looking for real world figures to see if it is worth the extra cost and with which motor.
I’m looking to get 4 small people in and out of 2000’ strips without taking any branches at the end of the runways with me. I wanted initially to cruise at 150mph, but I’m ok with 130mph now.
Thx
DJ Balla offline
Re: Tri-pacer vs. tri-Maule??
Tripacers do not fly at 130 mph in cruise. If you want faster than 120, it is the wrong plane, and most of them are more in the 105 to 115 mph range unless you really dress them up for speed with small tires and fairings.
Troy Hamon offline
Aircraft: Piper PA-22
The TriPacer is a good airplane but there's no comparison, even to a 180HP Maule.
Especially if looks count ;-)
Mountain Doctor offline
Aircraft: Maule MXT-7 180A
Troy Hamon wrote:Tripacers do not fly at 130 mph in cruise. If you want faster than 120, it is the wrong plane, and most of them are more in the 105 to 115 mph range unless you really dress them up for speed with small tires and fairings.
I should have stated in the original post I am looking at 160HP Tri-Pacers only. Likely vs 180hp constant speed propped Maule.
DJ Balla offline
Tri-maule's are disgusting. Get a tripacer. They are at least ugly in a good/endearing way.
Also, btw Troy I spotted your PA22 in King Salmon last week, I'm a fan. We got 2 tri pacers to do flight instruction in and one of them is painted nearly identical to yours.
asa wrote:Tri-maule's are disgusting. Get a tripacer. They are at least ugly in a good/endearing way.
Once you've sat behind a Lycoming 540 in a 4-seat aircraft, it's hard to go back.
Tri-Pacer: Honest, gentle flying bird. No toe brakes, just a hand brake. One door on the right side. 160hp surprisingly good performer.
MT-7: TWO doors, huge cargo door, available with 235-260hp Lycoming for hauling meat at higher speeds. Constant speed prop. Toe brakes (woo!) All things normally objectionable about the Maule.
60% of all threads on BCP:
I don't want a 182, I just want a plane that does everything that 182 does, nothing more, nothing less.
asa wrote:60% of all threads on BCP:
Someone once told me that everyone ends up with a 182 eventually. I guess there are some slow learners here.
Probably right. There is a reason that there are so many 182s out there in the world but that doesn’t mean that they are for everyone.
DJ Balla offline
Thx
My 1956 182 is just a bit short of 150 mph cruise. It has a 1000 pound useful load. I operate out of 1000 ft of grass at 2640 foot field elevation. I understand why a 172 is out for the mission you described but an explanation of why a strait tail 182 is out would be interesting to here.
Sex isn't for everyone either.
Just for the record I DO NOT want a 182, great airplane but it doesn't have a round enough tail, I like round tails !!!!!!
Many options there too. Look at all the robots they are producing and declining birth rates in certain areas.
DJ Balla offline
Mapleflt wrote:Just for the record I DO NOT want a 182, great airplane but it doesn't have a round enough tail, I like round tails !!!!!!
True. The Cessna 170 may be the best looking plane they made.
I get it, 182’s probably don’t have a high enough Vne for the DJ.
I am curious if simply painting a new red line (thicker than original one obviously) on the ASI changes the Vne or if there’s more to it?
You clearly understand the 170 obsession, thank you kind Sir
Yes...the abilities are very different. They have a common general form factor but they are really different airplanes.
Troy Hamon offline
This made me laugh. Very true, though.
Troy Hamon offline
Saw a really nice 170 with a 220 Franklin in it. Just WOW
Part of my reasoning is that a 182 is big and heavy and needs 6-cylinders to do its thing vs the other two planes in my original post which are not as heavy and use 4-cylinders. My assumption is that this would result in lower fuel and overhaul costs vs the 182
DJ Balla offline
