Zzz wrote:The engine though, you just have to have it bolted on with the prop in order to do some steps, like the cowling build/assembly and layout of certain firewall-hung items like brake reservoir, oil cooler, gascolator, the heat box, battery, etc. You get to a point where there are all these steps you could start on, but they require the engine to be in place.
Just so you know, the engine is miles away from the firewall in a BH. Nothing like a Skywagon for instance.
Provided you don't mind too much where you hoses and ducts run, you could definitely get away with doing a lot of that stuff ahead of time. If you wanted to.
The risk is, you end up with extra holes in the firewall.
