Backcountry Pilot • Work'n the numbers
Work'n the numbers
24 postsPage 1 of 21, 2
Work'n the numbers
Does anyone in the BCP community have a handy dandy excel W & B program. It's time to see where the 170 is sitting after the engine change and other "refinements" in the C or G envelop, the empty weight is 1340 lbs.
Re: Work'n the numbers
I just do my W&B on paper, it's pretty simple. While you had it on scales did you weigh it in different configurations? Ex:with rear seat in, with seat out, with pilot seat only, etc? I think it's well worth the time to do that, that way config changes are a simple log entry referring to certain ammendments. I think I have 7 different ones for my 206.
I’m usually configured with only 3 seats and will do up a two seat W&B as well. Plus I have three different landing gear configurations to go between, wheels, wheel-skis and floats.
1340 is a really nice weight for a 180 hp 170B. I think mine was ~1356 empty on 8.50 tires.
Congratulations!
mtv wrote:1340 is a really nice weight for a 180 hp 170B. I think mine was ~1356 empty on 8.50 tires.
Congratulations!
Thanks Mike
I might have one hiding somewhere, I'll look.
A1Skinner wrote: I just do my W&B on paper, it's pretty simple. .....
x2
x2
It's not that a W & B "on paper" is terribly challenging, even for ME. However when the document is part of a package that's being submitted to a regulatory agency the optics of a "formulated" process could be helpful.
Mapleflt wrote:
x2
I could send you my word document one that I send in to TC all the time. Basically just a fill in the blank with the numbers.
A1Skinner wrote:
Mapleflt wrote:
x2
Cool, thanks A1
Mapleflt wrote:
A1Skinner wrote:
Mapleflt wrote:
hotrod180 wrote:[quote="A1Skinner"] I just do my W&B on paper, it's pretty simple. .....
x2
Cool, thanks A1[/quote]Done. Check your email.
Hey Zzz, how about a "tools of the trade" section. A1 Skinner just sent me a really simple (for me it needs to be) W & B worksheet, what ya think :wink:
I would love to get that W&B worksheet for my build if possible
Jay dot Townsend zero seven at gmail dot com
[email protected]
Thanks
Utah-Jay offline
Aircraft: Bearhawk Companion
I'll leave it to A1 to pass along he's the original author or I'd be happy to with his permission. I did find a PDF W & B report I'll send you but the data fields are "locked" and will require manual input.
x2
Nothing's simpler than changing a number in a spreadsheet and seeing values change. W&B on paper is easy but having an electronic version to play around with adjusting loading is even easier and it's quick.
Bryce, I suggest you learn Excel or Google Sheets. 8)
Here’s one I put together for my N number.
Zzz wrote:
x2
Man I'm too close to retirement for that to happen. :roll:
Mapleflt; X2 bigtime.
flyingjack offline
Aircraft: Husky/T206H
Utah-Jay wrote:I would love to get that W&B worksheet for my build if possible
[email protected]
Thanks
I'll send you a copy Jay. Stand by at your email.
Maybe I'll sit down one of these nights and design one on Excel. Just haven't had much time, working on my CPL every evening so I can take the turbine Ag seat I've been offered for next summer.
Mapleflt wrote:....It's not that a W & B "on paper" is terribly challenging, even for ME. However when the document is part of a package that's being submitted to a regulatory agency the optics of a "formulated" process could be helpful.
8GCBC's W&B should do the trick then, it is impressive.
"Blind them with brilliance or baffle them with bullshit" comes to mind.
This one does both to me (no offense to 8GCBC).
