I have a few extra 170 parts around in the business that I am in. We buy and sell salvage aircraft. I was able to cut down a T yoke I had to try out what I was planning to do because I have two more at my disposal currently if I had to go back to the original setup. Besides all my time that has went in, it can go back to original if not approved. This was in the plan.
It is a VFR airplane that I want to fly mainly in the backcountry here in Idaho. I dont need the center stack for a bunch of big fancy radios, was mainly just trying to clean up the mess of a panel that was cut up over the years and go more modern while doing it with the 6 pack style. The T yoke was going to be used to simply keep it somewhat standard and hope for an easier approval that way by using the part that was already part of the airplane originally. The center panel was just to mount a radio and transponder up high and an Ipad mount down low that didnt require much clearance, therefore a U style was not necessarily needed.
A lot of other 170 panels that have a U yoke have for the most part been cut down using the bottom part of the original to keep the same pivot point. This allows the center stack radios and a 6 pack layout. Avion and Del-air both do a bit different but there are some out there that are shorter than standard 170 height allowing the 6 pack design. I met someone through the 170 forum that did a similar design with a 6 pack layout similar to mine but with a U yoke and got a field approval. Wasn't recently done and may have been easier when he did it, I'm not sure.
I appreciate all the feedback and advice so far. From here forward I am going to mostly focus this thread on the rest of the build as it happens to keep it moving forward. I will deal with the panel fiasco as I go.
