robw56 wrote:I’ve been thinking for a while now about getting 206 middle seats to replace the rear seats on my 180. I’d like to have some comfortable seats back there for my kids, not any of the jump seats that are available. (I currently have Cessna jumpseats). I know Kenmore sells the STC. Does anyone know which part numbers can be used for this STC? I see some deals come up on seats every once and a while on eBay or barnstormers... but I don’t want to buy anything without confirming what part numbers will work and what won’t.
Bigrenna wrote:FWIW... I didn't like this mod at all. I had it in my bird when I bought it, and it was one of the first things I tossed when I started my resto. I found them really big and heavy... took up tons of valuable space in the back.
The install is also pretty booty fab and not very strong. I know the Atlees are not the most comfortable for rear pax, but so they are so much more convenient as well as robust.
Just my 0.02.
I will see if I can dig up the old paperwork for you Rob.
RKTX wrote:Had 206 seats in our 180 when we first got it, yes they are comfy, but that's about it. The install of the seat rails in ours really was not great, kind of flimsy, and our seats were kind of a pain to take in and out because of the big comfy upholstery (about 20 Lbs each, ouch!). Ended up ditching them real quick, and going back to the bench seat. Honestly, the bench seat is lighter, quicker and easier to take out, and a hell of a lot stronger than the 206 seats. Being that I fly around 95% of the time with the back seat out, I couldn't justify the cost of the Atlee seats either.
c180bill wrote:I have a spare stock seat in nice condition at KEDU.
You can have it if you want.
--Bill
hotrod180 wrote:I lusted after a set of BAS seats back when I had my old C170,
but couldn't talk myself into ponying up the dough for them.
I ended up installing a single RH C185 factory jump seat,
which I managed to buy cheap from someone- probably because he only had the one.
Like you said, Rob, they're too far forward so not really comfortable for anyone above about 3' tall.
However, there is some demand for them.
I'm sure you could sell them for enough to buy a bench seat and/or the bracketry required for same.
You'll need different seat belts--
they mount on the seat itself with the bench.
I'm not sure that the rear seat upper seatback bracket set-up is the same for all the 170/180's--
the one in my 53 C180 is the same as was in my 48 C170,
but I seem to recall that they changed it after some years went by.
If you go this route, be sure the seat matches the bracketry..
Those brackets are still in my C180--
they make a good place to hook the bungee cords that secure my BAS seats in the stowed position.
