shortfielder wrote:You seem to be resisting getting the correct torque plates. When I bought my kit from Wup, it came with correct ones, and there were no issues after that. Brakes are pretty important. My feeling is that is no place to compromise. I know new ones are a little spendy, but stioll piece of mind. There are plenty of good used one around.
Gary
Yes, you are right about my resistance. There's always an ideal option, but if my existing parts could be safe and reliable, then that means spending less, which means working less, which means more time for other fun stuff. It looks like with my current brake wear I'd be getting out so that half of my pins would be engaged, but as the linings wear further, that would get worse.
Here's what I gather about the part numbers for the torque plates, researching other threads here and Cleveland parts diagrams. The originals on my 199-60 kit are part of the 30-52 brake and part number 075-01500.
The 199-62 kit includes a brake disk that is about 1/4" deeper, and brake 30-52N, which seems to vary only in the torque plate, which is number 075-05401.
It looks like one of my favorite salvage places will sell me a pair of the 401s for under $200, so I'll go that route.
In the end, this position will be good. If it becomes advantageous in the future, I'll be able to swap back to the original configuration and still be able to fit a set of 600x6 tires into those large fiberglass parts that I'll not mention here by name.
