jaredyates wrote:Has anyone run into compatibility problems with the 26" Goodyear tires and clearance from the brake calipers? My wheels and brakes are the Cleveland 40-75b, which includes the 164-01501 brake disc. A deeper brake disc would provide more clearance, as would some sort of spacer between the brake disk and wheel.
Even with the correct setup there is no way around rubbing between the brakes and tires. This problem is exasperated at low tire pressures. The only way to fix it is the alluminum disc spacer in most cases.
Airframes should sell the disc spacers, stoddards airparts has them. The Cessna caravan even uses an brake disc spacer approved with an STC when running 29 tires.
jaredyates wrote:Thanks everyone, the blue lines in the image show the problem exactly. If I put spacers between the brake disc and the wheel half, is there any concern about that changing the alignment of the disc relative to the caliper? The spacial orientation is confusing, but I gather it would cause the caliper to float further out on the pins?
Zzz wrote:All you're doing is moving the wheel and tire away from the brake and disc business by adding that shim between disc and wheel hub. The bigger problem I see is running out of axle length. I have minimal threads exposed on my axles with my current setup and that clearance I stated earlier.
jaredyates wrote:...The spacial orientation is confusing, but I gather it would cause the caliper to float further out on the pins?
bart wrote:Zzz wrote:All you're doing is moving the wheel and tire away from the brake and disc business by adding that shim between disc and wheel hub. The bigger problem I see is running out of axle length. I have minimal threads exposed on my axles with my current setup and that clearance I stated earlier.
Are you sure about this Zzz?? An axle spacer would move the entire wheel/rotor assembly further out, not changing the clearance between the rotor and wheel. A 1/8" spacer between where the rotor mounts to the inside half of the wheel would provide a 1/8" more clearance between the caliper and the tire, which is what I think is the goal here. The only problem is that you need to make sure your caliper pins are still all the way inside the torque plate when you add the spacer. (this is where the diagram above is wrong, it shows the caliper hard mounted to the torque plate which isn't the case.) If you use a 1/8" spacer, you should stick your finger inside the wheel and make sure you have at least 1/8" of pin sticking out of the torque plate. This excess will go away when you add the spacer.
The way I see it you have two options to change the spacing between your caliper and tire:
1- a spacer between the rotor and wheel, which would necessitate longer wheel bolts.
2- a different part number brake rotor with a deeper spacing. (more $$$)
bat443 wrote: Just as a note the 199-60 kit is for 600x6 tires and the 199-62 kit is for 800x6 tires for the same model aircraft. Hope this helps.
