Could someone running the Desser smooth 8.50s post some data on the diameter of these tires, inflated an mounted on a plane?
mtv wrote:Could someone running the Desser smooth 8.50s post some data on the diameter of these tires, inflated an mounted on a plane?
mountainmatt wrote:mtv wrote:Could someone running the Desser smooth 8.50s post some data on the diameter of these tires, inflated an mounted on a plane?
I'm seeing about 21 3/8" to 21 1/2" on my 180 at 18-20 PSI. I think the Goodyear 8.50's have it beat by 1/2" or so (full tread).
I've come to like these little tires on my 180 for my mission. They wear well, don't throw rocks, soak up the bumps within reason, and haven't slipped. I have about 65 hours / 125 landings on them (60/40 pavement / grass).
corefile wrote:Agreed - that 8.50 goodyear looks bigger then other side by sides I've seen.
According to Goodyear:
8.00x6 is 19.5" diameter
8.50x6 is 22.1" diameter
In that picture the 8.50 looks a lot bigger then 2.6 inches over the GY 8.00
North River wrote: Geez, you guys don't even believe a photo! ......
