This pic was also handy for the truck drivers, texted to them so they knew exactly where to park and off load, as it was tight and busy quarters this was important. As always, this is a service I offer my customers AT NO EXTRA CHARGE courierguy wrote:While I was admiring his flying, I hope he noticed my fast cycle time and smoothness in swinging those trusses in!
You gonna manage any CE180 energy up to Alaska this year? I tell ya, the weather in SE absolutely sucks so far.Rob wrote:The first pic *appears* to be an AT-602. If the hammer was down, and the load was light he may have been doing as much as 160 mph across the field. All that energy has to go somewhere on the way out.
FWIW, I prescribe to the theory that energy management can and does encompass power management. Consequently I most often DO come back on power as the load lightens (unless I am in a gutless wonder). If I had the energy to get it turned around with a full load on, I will most certainly have the energy to get it turned around with a reduced load, and less power = less distance, height, and consequently TIME in the turn. That is time that is not earning a paycheck....
Somewhat OT, but related to the aircraft.... Speed across the field does not always = more money in the bank. An AT 802 will absolutely smoke a 400 gal Thrush through the field, but put them both on a 40 acre block, and the S2R will out turn the AT (assuming similar caliber pilots) by a margin such that they will both finish within a second or three of each other, with the S2R having burned half the fuel, insurance, and airframe reserves... As with anything else aviation, choosing in accordance with the mission is the best way to assure smiles![]()
Take care, Rob
gbflyer wrote:You gonna manage any CE180 energy up to Alaska this year? I tell ya, the weather in SE absolutely sucks so far.
