I could not find the thread I was looking for, so made this one, This looks promising!!
Tiny and $1300 bucks??
https://www.aopa.org/news-and-media/all-news/2016/august/03/new-ads-b-transceiver-is-smallest
Mountain Doctor wrote:Not TSO'ed...
hotrod180 wrote:ADS-B devices can be moved from airplane to airplane, but as I understand it the ADSB-out units will each transmit a code which will be linked to a specific tail number. So each airplane will need it's own specific unit.
M6RV6 wrote:I could not find the thread I was looking for, so made this one, This looks promising!!
Barnstormer wrote:M6RV6 wrote:I could not find the thread I was looking for, so made this one, This looks promising!!
Nice find, thanks. I wouldn't be surprised to see these get smaller and cheaper. It won't come from the aviation avionics industry, they are used to being able to sell everything at premium prices, and in fairness to them the market is small. However the burgeoning UAV industry is another matter. They potentially have millions upon millions of customers, those customers will require lightweight and inexpensive. As we get closer and closer to 2020 the units will get smaller and especially lighter and less expensive. If the FAA holds the line of not allowing units to be transferred between aircraft then they are setting the stage for an outlaw culture, however small it may or may not be - IMHO anyway. Get out the popcorn, ought to get interesting.
hotrod180 wrote:ADS-B "in" devices can be moved from airplane to airplane, but as I understand it the ADS-B "out" units will each transmit a code which will be linked to a specific tail number. So each airplane will need it's own specific unit.
\hotrod180 wrote:hotrod180 wrote:ADS-B "in" devices can be moved from airplane to airplane, but as I understand it the ADS-B "out" units will each transmit a code which will be linked to a specific tail number. So each airplane will need it's own specific unit.
I found this interesting tidbit on the Navworx website,
http://www.navworx.com/navworx_store/Ce ... 600_B.html
"AutoStealth(tm) Mode:
The UAT technology is the only ADS-B equipment that will allow for privacy. Normally, ADS-B devices transmit the aircrafts ICAO number, a unique code that is assigned by the FAA to each aircraft. When flying VFR however, there is no need to let the FAA know who you are. The ADS600-EXP randomizes the ICAO whenever the squawk code is set to 1200. In addition, the N-Number of the aircraft configured is changed to "N0", an unassigned N-Number"
Timberwolf wrote:Put in a dedicated toggle to the ADSB unit so you can turn it off when times arise.
Timberwolf wrote:I mostly prefer to turn it off because I enjoy flying low out over the bay where there aren't any vessels and it's perfectly legal, yet it isn't something the controllers are used to seeing on their scopes. Instead of concerning them and to avoid having a controller who is unfamiliar with regs, it is just easier to not squawk and never show up on the radar to start with. But the bigger fact is it's none of the governments business where I fly my personal aircraft. I'm glad Navworx anonymizes the ICAO when squawking 1200.
<snip>
Cary wrote:Why would anyone want to turn off their transponder/ADS-B Out? Drug runners? Escape the Blackhawk after busting a presidential TFR? Fly through a restricted area? All that's silly.
Ace007 wrote:Cary wrote:Why would anyone want to turn off their transponder/ADS-B Out? Drug runners? Escape the Blackhawk after busting a presidential TFR? Fly through a restricted area? All that's silly.
Because anyone (including noise complainer, nut-job Kim Gibbs) can look up a transponder track on webtrak, get your N number from the ICAO code, look up your name and address from the aircraft registry, and then drive to the airport to harass you and publish everything on the internet like she did here:
http://www.freerangelongmont.com/2012/06/05/reckless-helicopter/
It's time the FAA (with prodding from AOPA/EAA) got our personal info off of public website. I can't look up car license plates on the net, neither should I be able to look up N numbers.
