Congratulations!!
By chance, did you take your practical tests with Tom at MCTC in Minneapolis yesterday? I thought I saw someone testing that looked like you. Regardless, awesome job!
hotrod180 wrote:That stamp says it's been inspected but not that it is airworthy.
As a non-licensed mechanic owner, it seems to me that the IA would have to make another entry,
signing off the airplane as airworthy after the A&P corrected any discrepencies.
Eric, I’ll try to answer your question as it was explained to me. This took me some mental gymnastics to understand the reasoning but this is what we were taught. Hopefully I’m not spewing bull. lol.
Anyways, 43.11(a)(5) reads “Except for progressive inspections, if the aircraft is not approved for return to service because of needed maintenance, noncompliance with applicable specifications, airworthiness directives, or other approved data, the following or a similarly worded statement - “I certify that this aircraft has been inspected in accordance with (insert type) inspection and a list of discrepancies and unairworthy items dated (date) has been provided for the aircraft owner or operator.””
The key word in that string of text is the “needed maintenance, non compliance with applicable specifications, airworthiness directives or other approved data”. An A&P is allowed to do maintenance with the added benefit that the A&P’s signature is what allows the aircraft to return to service. If the maintenance requires a major repair/alteration, then an IA would be needed to return the aircraft to service.
As an owner that’s presented a discrepancy list that would result in a flunked annual, the smart thing to do in this situation is to make sure that your IA does not put the discrepancy list IN THE LOGBOOK. The discrepancy list is only required to be provided to the owner/operator as the FARs do not state that such a list must be included in a logbook entry.
On the other side of the coin, a smart IA would hold onto such a discrepancy list in case the FAA ever took up an interest in the maintenance history of the airplane. That being said, as a mechanic, I’m going to keep a detailed personal logbook of work that I’ve done so that in the event that the FAA takes up special interest in an airplane, I’ll be able to back up the logbook entries.
Mike Busch wrote an
interesting article on the subject.
