mtv wrote:Cam,
I'm really fascinated by that airplane. You've provided some info, but now that you've done the ultimate cross country flight with it (couldn't get a whole lot longer....Pt Lay to Key West, maybe, when you have some time, could you tell us more about the plane?
It's a sweet looking ride, and obviously fast.
I did one 9.1 hour flying day enroute back from OSH this summer in the Cub. Haven't done one of those in a long while, and was actually surprised that I wasn't more stove up. Hotel room, hot shower and a good steak that night in Miles City helped the recovery
. Oh, yeah, and an adult beverage or three.
Tell us more about that beautiful little machine when you're rested up. Looks to me like you scored big time......
No problem! I'll start off by saying this airplane is much faster than I thought it would be. Roger put a real winner together!
It was formerly a '59 Tripacer that lived in WI, TN, NV before it made its way to AK, where it resided in Tok and then Kenai for a while. Roger bought it in '02 and began the restoration process that ultimately ended with an E-AB certificate.
The major alterations are the RV-6 cowl that required widening and reshaping as well as a hand-fabricated boot cowl, the addition of plexiglass everywhere in the cockpit (to include a full skylight), and the Grove one-piece spring aluminum main gear (gun drilled for the brakes). He also built an all metal interior which is beautiful, and installed Atlee Dodge 30.5 gallon tanks. Everything else is pretty much standard Pacer, though Roger cleaned up the frame to a "like new" condition.
The motor is a wide-deck O-320 with 160 hp pistons, and the prop is a 74 inch Sensenich that was re-pitched to 56 inches. I don't know if it's enough prop as we had to take care not to overspeed the engine, but it swung to 2350 static. I'd love to see what a CS would do. Maybe I'll try one out one day after it's paid off...
We cruised around 2450 to 2500 rpm for most of the trip, and fuel burn was predictably around 9.2 gph. One early leg we flew at 2300-2350 rpm and saw 7.4 gph. Another early leg we flew between 2350 and 2400 rpm and saw 8.4 gph. To lean we just pulled the red knob out until the engine stumbled, then increased until the engine smoothed back out. We then watched the CHTs and richened as necessary to keep below 400 degrees as a max temperature and 380 degrees as a continuous temperature. At 2450-2500 rpm, the Racer indicated 135 to 140 mph at 3-4,000 msl. At the same RPM we saw 120 mph indicated at 9,500 msl.
During climb out in the lower 48 we kept airspeed around 105 to see between 500 and 250 fpm above 5,000 msl. It was necessary to keep the speed so high to keep the oil temps down. I saw 235 degrees during one climb out before we start climbing at much higher airspeeds, trying to keep oil temps lower than 220 degrees.
The only squawks from the trip are the head temperature spread between cylinders and the tach timer broke as it swung over 100 hrs. Right now the plane has 103.6 total time
The airplane is nimble and fun to fly and control forces are very light. It's really hard to slow down to flap speed
In all, I'm VERY happy with the airplane. Roger is a craftsman and did an excellent job building the Racer. I need to work on my technique to see how short I can get it off and landed in, but I imagine it'll be very similar to a certified Pacer. Plus I can cruise much faster.
