Jeredp wrote:Will your kit use the standard cessna axles? I'm looking forward to seeing the prototype sitting on the gear. Thanks for your efforts, this is getting exciting for those of us with training wheels
I am hoping to offer three options... the original axles that you removed from your 172 gear legs, Cessna solid axles, and aftermarket solid axles. This will give you the option of re-using stuff you already have, or upgrading to heavier duty parts.
I want to minimize the stuff I force you to buy, and allow you to use as much of what is already on the airplane.
You will be able to re-use your OEM wheels and brakes, or (of course) put on Clevelands which has long been approved, and (hopefully) also have the option to upgrade to a newer wheel and brake assembly if you like. We're going to do the drop tests using the new aftermarket axles and wheels, so they are automatically included in the certification.
One of the projects I want to do is offer three different tailwheel options. A lot of people have or can get a used Scott 3200. A lot of people will want to use an ABW unit. And some people may be interested in a third option, for a less expensive and more simple tailwheel (not a Maule, another design altogether), which I can
possibly offer. This will take some serious tap dancing with the Federales.
This week's project is finalizing the design and function of the main gear retaining and clamping system. Instead of Cessna style shims, we're going to hold the gear into position with (jackscrew principle) clamps, so that (hopefully) the toe-in and toe-out can be adjusted with a wrench instead of tapered shims at the axle. I never understood how you're supposed to line up the bolt holes between the axle sand the gear leg when you introduce a wedge shim... either you bend an arc into the bolt, machine a curved bolt, or goober up and oval out what should be reasonably close tolerance holes to get the bolts in.
This principle will also be used to eliminate the Cessna shim at the top of the gear box. Instead of hammering and banging on a thin shim which will only get crushed and squeezed into tatters, I came up with a system that clamps the gear leg up against the outboard gear box fitting, and can be tightened in the field with an Allen wrench. I'm HOPING that the real-world back country flyers will appreciate this capability, since a loose or rattling landing gear will quickly beat the crap out of the attach fittings in rough service.
Anyway, thank you all for the positive feedback, and for being interested in this as it progresses.
