CamTom12 wrote:1) do those still even work?
2) those are so cool!
hotrod180 wrote:I've been toying with the idea of a panel upgrade myself. I pulled the vacuum system & AH & DG gyros out of my last two airplanes (C170 & C150/150TD) for simplicity sake- plus, in both cases, one of the gyros went tits up and I didn't wanna spend money to overhaul what I never used. I've considered doing the same with my 180, but since it is a more serious traveling machine I thought it might be a good idea to retain them for "just in case" situations. I recently read an FAA policy statement saying you can now replace your vacuum or electric mechanical horizon with an electronic version as a minor alteration. This got me thinking again, only this time I'm considering replacing the vacuum stuff with a "pocket" Dynon. It has a horizon, plus GPS-based directional indicator, airspeed, altimeter, vertical speed, rate of turn, slid/skid ball, and probably a bunch of other shit going on also. About $1000, no approval paperwork required, since it's a handheld device, and (hopefully) longer-lifed and more dependable than the vacuum versions to boot.
hotrod180 wrote:I'm a day / vfr pilot, and so the Dynon would not be replacing any required instruments. It would strictly be for just-in-case situations. Even then, not much good unless I spend some quality "foggle time" once in a while.
Cary wrote:hotrod180 wrote:I'm a day / vfr pilot, and so the Dynon would not be replacing any required instruments. It would strictly be for just-in-case situations. Even then, not much good unless I spend some quality "foggle time" once in a while.
You've mentioned that before (day VFR), which still amazes me. No disrespect intended, but while I know a lot of VFR-only pilots, I know very few who never fly at night. Especially in the winter with shorter days, it's hard to go any place with the guarantee of getting there or returning without landing in the dark. FWIW, I stay night current year round, and I stay pretty close to IFR current most of the time--in fact, I have an IPC scheduled for Tuesday, as my last IPC was a shade over 6 months ago, and I've not flown enough IFR to be current otherwise.
hpux735 wrote:Cary wrote:hotrod180 wrote:I'm a day / vfr pilot, and so the Dynon would not be replacing any required instruments. It would strictly be for just-in-case situations. Even then, not much good unless I spend some quality "foggle time" once in a while.
I'm strictly vfr-day also. I've only been night current twice, once after getting my ppl, and once when I thought it might be a good idea.
When I'm flying in the mountains with my wife, I have a hard enough time being upbeat when she asks what I'd do if the engine quit. I don't think I could pretend that there were any good options during the night. On top of that, moonless nights might as well be hard ifr while enrute, and I'm not ifr, either.
Same here, though due to being color blind. Even though I could pass a light gun test and get the restriction removed, I don't much care for flying at night over the mountains anyway.
Cary wrote: You've mentioned that before (day VFR), which still amazes me. No disrespect intended, but while I know a lot of VFR-only pilots, I know very few who never fly at night. ....
hotrod180 wrote:FWIW I know a lot of pilots who don't care for flying at night-- including some airline guys who don't do piston SEL night ops.....or day IFR for that matter.
