While walking around Osh Kosh '10 I stopped by the Bearhawk booth. I was curious to poke around one after seeing a nice example at the BCP fly in at JC this summer. I love my Stinson but eventually I'd like something with a little more interior room and useful load. I've had my heart set on a 180 as the best solution (and still really like them), so I was only casually looking over the Bearhawk when the "good idea fairy" struck and I started seriously contemplating it as an alternative.
After talking with the sales rep for a while I got signed up for a demo flight and returned the next day to give it a try. Despite a brief runway closure for a Bonanza that managed to ground loop into the grass (would it be Osh Kosh without some degree of Nascar-esque carnage?) we managed a quick departure off of 18L. There were only two of us in the plane and we were light on fuel so the takeoff roll with the IO-540 was brief. The throttle pretty much hit the firewall and we lifted right off from a 3-pt attitude. Very nice climb performance - pretty comparable to my Stinson with the O-470, not surprising given the similar weights and hp.
We departed the field on the procedure and made our way over to the east side of the lake where we went through a brief but thorough exploration of the flight envelope. At 24/24 @ 3k' we were indicating 160mph, down at 21/23 we saw about 135-140. The Bearhawk uses the same airfoil as the Stinson minus the leading edge slats and turn performance revealed the common DNA. It felt great through all manner of turns, leading with just a smidge of rudder smartened up the roll rate and negated the hint of detectable adverse yaw. It was much more longitudinally stable than my Stinson and I was intrigued to note that they do not see a need for rudder trim. I would think with that amount of power rudder trim would be essential but I didn't miss it.
Stalls were pretty benign. Not a lot of buffet though there was a bit of a break with good control after. Rudder was the answer to keep the wings level in contrast to the Stinson where the slats keep the ailerons effective at high alpha. We trucked on back and sequenced into the herd diving for the various runways. We set up on a tight, steep, left base to 18L (same approach that bit Jack Roush in the ass). With 40deg flaps on tap it comes down like a brick, a nudge of a slip yielded a greater descent rate and the demo pilot planted it right where he wanted to and we were stopped with maybe a couple hundred feet. The oleos soaked up the intentionally firm landing and facilitated great control on the short roll out.
I was very impressed overall. Builders are seeing about 1100-1300 lbs useful load and the Maule-style door on the right side means you can load about anything you'd want to haul in a plane. The visibility was great with the low doors and large windows. I also really liked sticks as opposed to yolks.
So now the wheels are turning as I contemplate getting involved with building a kitplane. Their quick build kit delivers a prepped and ready to go fuselage and wings that are largely done - just drop in your fuel tanks, plumbing, and wiring and then button them up. There is a lot you need to buy that does not com with the kit but that also means that you can set up your build just the way you want it. The sales guy said most guys are going with the IO-540 but there is also a contingent that intends to use an O-470 (as I would). There is also huge appeal to me to forego a vacuum system in favor of a solid-state EFIS - experimental opens the door to a huge array of options there at lower cost to boot. And the kicker of course is that if you build it you can then legally do most of the work on it, to include conditional inspections - no more tether to certificated regulations and associated costs.
So the question I'm asking myself now is do I really have time (not to mention the ability) to build a plane? And is half of my garage sufficient to do the work? I'm sure this is a standard thought process for anyone contemplating going this route...
