mtv wrote:I seriously doubt there’s going to be a big difference. Which tires are you going to run on the plane? That’s what you should train on.
A question: Why is your instructor suggesting this? How much experience does this instructor have instructing in these planes? Sounds like a newbie maybe. Most experienced tailwheel CFIs wouldn’t even think of changing between those tire sizes.
DENNY wrote:I would agree with mike. Several factors are involved in the "bounce" Tire size end pressure is a small part. Your plane has simple spring gear so any energy you put into it is going to want to come back out. Some will be used supporting the weight of the plane, but you gear went form nothing to a dynamic compression on landing. Low tire pressure will help some, size not so much. Being a new pilot I suspect you are landing at 10-15 mph over stall speed, full flaps, three point. With the instructor saying keep the yoke in your gut. What no one points out is that that is what you do when you want the plane to take off. High AOA with full flaps and good airspeed. You are trying to make the plane fly!! The bounce is just plane doing what it should but failing to stay airborne. because the speed is bleeding off. I could get 2-3 bounces when I started. You need to kill the lift of the wings!!! Lift the tail and stick the mains. Works with any size tire. Do a search and read posts from MTV, follow his advice. Also read up on the MAF technique.
DENNY
Green Ice wrote:DENNY wrote:I would agree with mike. Several factors are involved in the "bounce" Tire size end pressure is a small part. Your plane has simple spring gear so any energy you put into it is going to want to come back out. Some will be used supporting the weight of the plane, but you gear went form nothing to a dynamic compression on landing. Low tire pressure will help some, size not so much. Being a new pilot I suspect you are landing at 10-15 mph over stall speed, full flaps, three point. With the instructor saying keep the yoke in your gut. What no one points out is that that is what you do when you want the plane to take off. High AOA with full flaps and good airspeed. You are trying to make the plane fly!! The bounce is just plane doing what it should but failing to stay airborne. because the speed is bleeding off. I could get 2-3 bounces when I started. You need to kill the lift of the wings!!! Lift the tail and stick the mains. Works with any size tire. Do a search and read posts from MTV, follow his advice. Also read up on the MAF technique.
DENNY
You're exactly right! That's precisely what the first instructor had me do. Every landing ended with the plane dropping 3-5 feet after lift was lost. He said that I was doing excellent, but I have watched enough tailwheel planes land to know that's not right. Never was taught to do a wheel landing so I don't know what a good landing feels like. I'm hoping the second instructor will be much better. Thanks so much.
Mapleflt wrote:I give up what is the MAF technique ??
Mapleflt wrote:Thanks MTV,
I wasn't making the connection at all between a landing technique and a missionary effort however I was very much aware of MAF's existence.
I was taught this technique as a young pilot many, many years ago and had never heard it referred to as anything else but a "three point landing" along with the two point "wheel landing". It's always a bit interesting to hear how these terms and colloquialism seek into the jargon.
Cheers
mtv wrote:It’s NOT a “three point landing”. The point of the exersize is to touch on mains only, but with the tailwheel a few inches from the surface, then at the touch, roll the airplane up into level attitude. This offers the “best of both worlds” : Touchdown at very slow speed (same touch speed as three point), but any residual lift on wing is killed, rudder is up in clean air where it has authority, and the pilot can see what he/she is about to roll over.
The technique works great in planes with spring gear, by reducing the energy state at touchdown, thus reducing bounce. But it works fine in most taildraggers as well.
