Runway notamed close, lots of new snow, landed anyway. Glad no one got hurt. That could have easily ended much worse!
http://denver.cbslocal.com/2015/12/23/small-plane-crashes-into-snowplow-at-telluride-airport/#.Vnv6e4gbn-o.mailto
On 9News last night, they said there was 7 miles of visibility, so even if they were making an instrument approach, they should have been able to see well enough.
And it shouldn't be the plow driver. I had a few instances of showing up to a place not knowing about a Notam. Usually on a local flight with a spontaneous change of destination or coming out of the backcountry after being off the grid for several days. It's definitely easier these days with the better tools that we have, but still not perfect.
mtv wrote: And, you can bet that a quick call or two on the CTAF would have drawn a response from the plow drivers, who would likely have vacated the runway for the jet to land. .....
SixTwoLeemer wrote:Airport was closed and had been for many hours. Runway covered in snow. Feliz Navidad![]()
We're comin'
Denver Center would likely relay that info if you cared to check-in, no??
hotrod180 wrote:mtv wrote: And, you can bet that a quick call or two on the CTAF would have drawn a response from the plow drivers, who would likely have vacated the runway for the jet to land. .....
You're assuming that the plow had a com radio. Sure seems logical, and only common sense, but that's no guarantee they had one. I've seen lots of ground vehicle ops that were (foolishly) NORDO.
I agree, though, they should have spotted the plow. I wonder if the AWOS has anything about "watch for snow plows on the airport"?
I just checked NOTAMs for KTEX, there's one today for a runway closure 1541-1900Z-- I'm guessing it's for plowing.
mtv wrote: There's actually a rule (The FAA ya know) that requires plow trucks to be on frequency when on an active runway. MTV
hotrod180 wrote:mtv wrote: There's actually a rule (The FAA ya know) that requires plow trucks to be on frequency when on an active runway. MTV
I think there's a rule about checking NOTAM's before a flight too, but you can see how well that one was followed. I've seen a lot of bonehead behaviour by airport personnel. One local airport near here (KOKH) had a guy sealing cracks in the runway a few years ago-- his little pickup was clear of the runway, but the airport manager not only drove down the runway but also parked his car on it to check on his progress. No NOTAM, no radio, no nothing. About that time, an airplane was doing a long low straight-in and at the last minute realized that *holy shit! there's was a car on the runway!* so he went around. Afterward, the airport manager talked about reporting the pilot for buzzing him.. Unbelievable.
