I use these guys...
https://www.tsflightlines.com/
Interesting. Usually having the bleeder on top makes it harder to bleed. Hard to push the air out of the piston and back up through the line on my experience. Looks nice and streamlined though.On The Fly wrote:I did it this way on my 182 about 15 years ago. A somewhat more streamlined install than the way it was originally. It works perfectly and makes bleeding or adding fluid a little easier. The zip tie should be replaced with an Adel clamp.
A1Skinner wrote:Interesting. Usually having the bleeder on top makes it harder to bleed. Hard to push the air out of the piston and back up through the line on my experience. Looks nice and streamlined though.On The Fly wrote:I did it this way on my 182 about 15 years ago. A somewhat more streamlined install than the way it was originally. It works perfectly and makes bleeding or adding fluid a little easier. The zip tie should be replaced with an Adel clamp.
Sent from my SM-G960W using Tapatalk
courierguy wrote: Harder to bleed? Try impossible! I eventually figured this out as my brake mounting options are very limited due to my winter time wheel ski mounting. One has the bleeder on the bottom, (lower then the in fitting, not really on the bottom) the opposite side it's not, and I can pump my bleed squirter until I get writers cramp and still not get all the air out. What I do now is simple: I pull the 4 bolts that hold the brake to the axle and this allows me to rotate it just enough to bleed it super easy, as easy as the other side.
Those work even with the bleed screw mounted on top of the caliper?Aryana wrote:Push the fluid up from the caliper using one of these 150ml syringes and you'll be pleasantly surprised.
They also work as a vacuum bleeder too if you prefer that.
3 Pack 150ml Syringes
https://www.amazon.com/dp/B07BJ9P8FP?re ... b_ap_share
A1Skinner wrote:Those work even with the bleed screw mounted on top of the caliper?Aryana wrote:Push the fluid up from the caliper using one of these 150ml syringes and you'll be pleasantly surprised.
A1Skinner wrote:I've never thought to suck out on the caliper with a syringe. Great idea! I'll have to give it a try! Thanks for the idea.
